Re: prg 2.5 and biggest tires?
I found this on Prg's web site. Can anyone confirm this?
Q: How big a tire can I put on my Titan if I install the PRG leveling kit?
GREG SAYS: Well, you can fit 33" tires even without a leveling kit. With installation of the PRG kit, most 35" tires mounted on a stock or factory wheel will clear without rubbing or with only very minor rubbing (however if you have the factory mudflaps you'll most likely need to remove them). What determines if you'll have rubbing is the wheel offset. Contrary to popular belief, the farther the tire sticks out the more chance you'll have of rubbing. This is because when you turn the tire swings in an arc. Rubbing occurs when the rear of the tire hits the inner fender liner. The more positive offset you have the bigger the arc the tire swings and the more likely it is to rub. Your best bet is to work with your tire and rim dealer to get a combination that fits properly.
Come on guys how bout some input.
2005 SE King Cab SE Popular Package SE Utility Bed Package w/Sliding Bed Extender Front Window Tint 15% Flowmaster Series 50 Dual Exhaust AEM Bruteforce Intake Dunder's Denali Grill AVS Chrome Bug Deflector Aries Stainless Steel Side Steps Stainless Steel Tailgate Trim Wade In-Channel Ventshades PRG 2.5" Leveling Kit 18 x 9 Helo Maxx 6 Chrome Rims 325/60/18 Nitto Terra Grapplers Bushwacker Fender Flares (painted) 4" CST Spindle Lift Parrot LS 3200 2 degree timing advance Bullydog Power Pup
