So I was a little bored today and decided to do a little photoshoot of my truck out in the snow, which turned into a photo essay about my tires. The parking lot outside the engineering building at school where I work had a fresh blanket of snow after being plowed early this morning so I moved my truck and put down a fresh set of tire prints. The results and findings turned out pretty good, as you'll see below.
The tires in question are LT285/70R17 BF Goodrich MTs, load range D. I currently have them inflated to 50 psi and have had them siped. To the uninitiated, siping on tires create extra griping edges, which helps a great deal on a mud tire. Due to the large lugs, there aren't as many griping edges per unit of surface area, compare an all terrain tire to a mud terrain and the difference is obvious.
This pic shows the effect of siping on the tread. I'm not sure if the method my local tire shop used is according to some industry standard or if tire shops all have there own way of siping. From what I heard on this forum, the price for this service ranges from $10-20 dollars/tire. Mine were done for $13/tire. Siping also helps extend the tread life of the tire by allowing the tread to flex and give more than it could if it was not siped, thus reducing wear.
The snow depth was ~1.5 inches, camera angle makes it difficult to spot in the pic.
Here is a measurement of contact width for the outermost shoulders that made contact with the snow. This was ~10 inches in width. The print probably would have been more apparent if the snow was deeper.
This measurement is of useful contact with the road surface. The tale of the tape is about 9 inches. Note that a width of 285 mm equals 11.2 inches on a tire calculator. This is the end of part 1.
