https://youtu.be/-iXe2dxUv9I @ 06)
https://youtu.be/_D4JqsntQuY @ 09 and :51)
The noise recently started happening about 5 days ago. It mostly occurs when I turn right, although sometimes it will sound when I go over bumps in the road and also at random times but this happens 95% less frequently. The wider the right turn, the more loud and dramatic the squeak. I changed my break pads and although they were low, they werent at the sensor. The rotor didnt look to bad, but the center of the wheel bearing did have what seemed like a decent amount of rust. The next thing Im tackling will be the wheel bearing, however every video ive seen on wheel bearing noises dont match my problem. Im wondering if maybe it sounds like suspension or any idea at all before I look into wheel bearings. Im no mechanic, this is my forst time really working on an automobile, and will take any ideas.
Thank You,
Thank You,
