Old 06-14-2006, 03:27 AM   #1 (permalink)
any1 know of a 33" tire in 18 wheel size
hi guys. i want to run 33s on a 18" rim with a prg minilift kit. i've searched and searched and it looks like i need a +offset and a backspacing as close to 5" as i can to prevent rubbing. im having trouble finding rims with that combo and tires. i really like the nitto terra grabblers at 325/60/18 but i don't know if thats too wide. is there a manufacturer out there that makes a 305/65/18? or a thinner tire that would prevent rubbing.
any suggestions would be much appreciated thanks.
johnwoo is offline   Reply With Quote
Old 06-14-2006, 07:15 AM   #2 (permalink)
themaildude's Avatar
Re: any1 know of a 33" tire in 18 wheel size
I'm running 325/65/18 terra grapplers on my KC 2wd with a prg level kit. I had to bend the pinch weld and reshape the fenderliners now it just rubs a little.
Click Here For My Mods
themaildude is offline   Reply With Quote
Old 06-14-2006, 08:24 AM   #3 (permalink)
rod_b's Avatar
Toyo Open Country M/Ts - 33x12.5-18
BFG A/T KOs - 285/65-18 (32.8")
8.04 K11 CC LE 4X OR BT PRG'd
rod_b is offline   Reply With Quote
Old 06-14-2006, 11:36 AM   #4 (permalink)
NorCal 4x4's Avatar
BF Goodrich All Terrain T/A KO LT305/65R-18/E2 124R ~(34x12R/18) 33.6" dia. (found at www.discounttire.com haven't seen it elsewhere, so maybe a new size)?
Most of the following are mudders and most are 12.5" wide:
BFGoodrich Mud-Terrain 35X12.5 QR18 ~(317.5/65/18) 34.5" dia.
BFGoodrich Mud-Terrain 37X12.5 QR18 ~(317.5/75/18) 36.5" dia.
Nitto Mud Grappler LT35x12.50R18 E 123Q ~(317.5/65/18) 35" dia.
Nitto Mud Grappler LT33x12.50R18 E 118Q ~(317.5/60/18) 33" dia.
Nitto Dune Grappler LT285/65R18 E 125R ~(33x11.2 18) 32.6" dia.
ProComp Mud Terrain 35/12.50R18 ~(317.5/65/18) 34.8" dia.
ProComp Xtrtreme All Terrain 35/12.50R18 ~(317.5/65/18) 34.8" dia.
Procomp X-terrain 35/12.50R18 (317.5/65/18) 34.8" dia.
Cooper Discoverer STT 35X12.50R18LT ~(317.5/65/18) 34.76" dia.
Toyo Open Country MT 35x12.50R18 123Q E/10 ~(317.5/65/18) 35" dia.
Old 06-14-2006, 03:52 PM   #5 (permalink)
thanks.
im only doing the mini lift so i could possible only run 33s on there without rubbing. any advice? can i do 34s? i really want the kmc backseat wheels with a 0 offset and like a 4.5 backspace i think
Old 06-14-2006, 09:35 PM   #6 (permalink)
ecbmxer's Avatar
Wow, I've never seen that size BFG! That would be sweet!
2005 Titan SE 4x4
Floor Mats
Splash Guards
Nissan Drop-in Bedliner
Front windows tinted to 35%
In-Channel Vent Visors
Front Husky Liners
STEREO:
Pioneer DEH-P8MP Head Unit
ecbmxer
ecbmxer is offline   Reply With Quote
Old 06-16-2006, 11:53 AM   #7 (permalink)
mdaigle's Avatar
i did a search on that size bfg (305/65-18) at discount tire and i come up with no results. are you sure about this size?
mdaigle is offline   Reply With Quote
Old 06-16-2006, 12:06 PM   #8 (permalink)
NorCal 4x4's Avatar
Yes, it it listed when searching Tire, by size. ( Then entered California and Sacramento for location). I think this is the p/n (38852)
http://www.discounttire.com/dtcs/sea...05&ar=65&rd=18
Old 06-16-2006, 12:21 PM   #9 (permalink)
eauxgod's Avatar
Kumho makes an AT that comes in 325/60x18 (33.4x12.8x18).
eauxgod is offline   Reply With Quote
Old 08-02-2006, 09:11 PM   #10 (permalink)
will these fit on 18x8.5 with +25 offset on a prg minilift w/o rub?
Old 09-12-2006, 03:17 PM   #11 (permalink)
Exclamation Re: any1 know of a 33" tire in 18 wheel size
anyone know where to get the 33" mud grappler for the 18" rims i cant find anywhere on the net selling those
barcode31 is offline   Reply With Quote
Old 09-12-2006, 03:59 PM   #12 (permalink)
rod_b's Avatar
I would call Discount Tire Direct if I were you. It's not listed on their site but almost every other size is.
Wheel and Tire Size Help YZmoto125 Titan Parts & Accessories 3 05-16-2006 08:04 PM
what size wheel/tire combo? cardesigner Titan General Discussion 14 01-17-2006 02:36 PM
Tire size for 22" and 24" rims? Chromematrix Titan Wheels, Tires & Brakes 8 11-07-2005 04:13 PM
Getting wheel wells shaved... What size tire do you suggest? K-MU Titan Wheels, Tires & Brakes 19 10-16-2005 10:03 PM
PRG 2"kit/wheel/what is the best tire size armymedic Titan Wheels, Tires & Brakes 3 01-23-2005 06:32 PM
