It looks great! I was just looking at those tires online yesterday myself. It is a pain to find tires for the factory 18" wheels. How is the ride, road noise, etc?
__________________ 06 Smoke SE CC 4X4 Bug Shield, in channel vent visors, 22% front window tint, PRG Leveling kit w/ 305/65/18 BFG AT KO's, JBA cat-back, 2* advance, AEM intake, BD Power Pup
Man those tires look awesome!! I am so glad somebody finally was able to fit 325's on the stock 18's. After I get DR's I'll try those or the procomp extreme at 325's if I decide to stay with an 18" wheel. I'm still debating on that or going up to a 20". What is the approved rim width for those tires? The procomp is 8", but the nittos are 9". Hopefully those are 8" as well.
2005 Titan SE 4x4
Floor Mats
Splash Guards
Nissan Drop-in Bedliner
Front windows tinted to 35%
In-Channel Vent Visors
Front Husky Liners
STEREO:
Pioneer DEH-P8MP Head Unit
Those are nice. Not as wide as the 325 ProComp Xtreme A/Ts. I think the ProComps are closer to 13.5 where as the Kumhos look more like 13" or less. How much do those run?
I GOT THEM THRU WHOLESALE TIRE COMPANY AND PAID 178.00 EACH.. YOU CAN FIGURE ANYWHERE FROM 25 TO 40 PERCENT MARK UP FROM SOME PLACES...THEY ARE ACTUALLY VERY SMOOTH AND FAIRLY QUIET.. I DROVE ABOUT 300 MILES ON THEM TO FLA. AND COULD HARDLY TELL THE DIFFERANCE FROM THE GOODYEARS.. THEY WOULD DO BETTER ON A 9" RIM BUT THEY MOUNT FINE ON 8"s JUS BE CAREFULL WITH THE AIR PRESSURES TO MUCH WILL MAKE THEM CROWN ..
__________________ 05 SE CC SE 4X4, utility pack, big tow,w/captain seats and Rockford Fosgate : GOODIES INCLUDE: Stillen leveling kit, K&N filter "looking at adding FRAMBOOST system", Flomaster Series40 Duals w/side exits, Nissan hood protector, Ventshade window visors, Aries step rails, Nissan fog lights w/new separate wiring harness and switch, Nissan allseason mats, KUMHO VENTURE A/T 325/60R18, clear bra, blacked out headlights
The pictures look different from yours. They are $177 each but shipping and mounting will probably add another $150-200.
Those look to be the right ones. The KL78 are the newest ones. I got a quote from Americas Tires for $201 each, mounted, balanced, and their insurance (free lifetime rotation, balancing, punture repair and tire replacement) included. I think I may go for a set.
wow, very nice, and thank you for posting sir i noticed their web site shows OWL for sidewall, did yours come that way and you turnd them inside? how much installed?
again, THANKS for the pics, im assuming no rubbing still?
D_C
05 Smoke SE KC 4X4, PRG Kit and 1.5" Fabtech Rear Blocks. Born 11/04, Adopted 01/05/05
Bone Stock Dyno Run 256HP with 317 Ft/Lbs
15.66 1/4 mile
03 Copper Suzuki SV650S 2X1 12.69 1/4 mile
THE ONES IN THE ADD ARE THE OLDER ONES. THE ONES I GOT ARE THE NEW VERSION AND THEY ARE BW BOTH SIDES .. I PAID 170.00 EACH AND MOUNTED THEM MYSELF.. i SUGGEST ASKING FOR THEM TO BE ROAD FORCE VARIATION BALANCING. I HAD TO TURN 2 OF THEM SEVERAL TIMES TO GET THE BEST FITMENT. THEY COME WITH THE RED DOT TO MARK THE TIRE AND ALIGNING THAT WITH THE VALVE STEM WORKED FOR 2 OF THEM BUT 2 I HAD TO PUT IT AT 2' CLOCK FROM THE VALVESTEM. THEY DIDNT TAKE AN EXCESSIVE AMOUNT OF WEIGHT EITHER WHICH PLEASENTLY SURPRISED ME... STILL NO RUB ISSUES.. I AM HAPPIER THAN A HOG IN IN FRESH MUD IN JULY....
Thanks for the pics man, they look better than I thought they would. What PSI do you run them? Also, if you had to guess, how much more heavy are they than the GYs?
I have been playin with the pressures.. started at 32 and truck felt a little loose in the rear side to side.. bumped em up to 40 which is the recommened ressure for the tire and seems be a stiffer better ride.. they are alotttt heavier than OE I could barely lift the damn things to get them back on the truck... they are also 8 ply where the goodyears are 6ply
