Old 08-29-2006, 01:21 PM   #1 (permalink)
gixxer0.6g's Avatar
Tire/Wheel Choices
First of all, what bolt patter do we have? Isn’t it the 6x5.5 (6-139.7mm) Is that right??
In my ongoing saga for a tire for a good price has lead me to this. I’m down to a few choices.
1. 265/70/18 Dueller Revos - $150/tire + $125 s/h = $725
2. 265/70/18 Kumho KL78s - $135/tire + $100 s/h = $640
3. 325/60/18 Kumho KL78s- $186/tire + free s/h = $744
Of those I think the bigger Kumho’s are my first choice. So I’m looking at almost $800 for tires which has lead me down the road of the cheaper 17” rims and tires. I can get the
Kumho KL78’s in the 285/70R17 for $113/tire and free shipping = $452
And a set of these wheels (attached) $150/wheel and free shipping = $600
Totaling around a grand. For the extra $200 I like the idea of getting wheels and tires. What do you guys think? Anything I need to know about 17” wheels and 285/70R17 tires and rubbing. What kind of backspacing should I be looking for? These wheels are 17x10 6-139.7HC-25A. I think that means a 10” width hub centric wheel. Is the 25 the offset? Somebody please help this rookie wheel junkie.
05 4x4 SE~
Performance Mods:
Banks exhaust, Nismo Intake, 2-Deg Timing Advance,
Exterior Mods:
Euroguard Brush Guard w/ 100w Spot Lights, fog lights, PRG Mini Lift, Low Profile Tonneau Cover, In Channel Vent Visors, Billet Grille, 17x8.5 MB Motoring Razor Wheels w/ 285/70R17 Kumho KL78s.
gixxer0.6g is offline   Reply With Quote
Old 08-29-2006, 02:13 PM   #2 (permalink)
gixxer0.6g's Avatar
Re: Tire/Wheel Choices
Also, what are the disadvantages to a mirror machined finish and what is an anthracite machined finish?
05 4x4 SE~
Performance Mods:
Exterior Mods:
Old 08-29-2006, 09:10 PM   #3 (permalink)
NorCal 4x4's Avatar
6x5.5 (6-139.7mm) Is that right?? yes.
If you have stock 18x8 wheels they have a +25m offset. I would never put a 10" rim +25mm rim on because if you keep the same offset the extra 2" of rim will be split equally, and you will rub the knuckle, at least on my Titan it would.
If you want to keep the clearance to the knuckle the same as stock, a 10" wide rim would have to have 0mm of offset. But since they will stick out 2" more than the OEM, they may rub the pinch weld.
But you don't need a 10" rim for a 285/70/17. That is the stock Off-road OEM tire size for the 17x7.5" rim with a +30mm offset. And people are running BFG AT LT315/70/17 on those rims! (34.5" x 12").
Silver '04 Titan SE Crew Cab 4x4 w/E-LOCK® - Born on 05/18/04 in the USA ... 33.5" Toyo M/Ts;
Old 08-30-2006, 08:38 AM   #4 (permalink)
gixxer0.6g's Avatar
Thanks for the info!
How would a 18x9 rim with a +10mm offset do? Does a postive offset put the wheel towards the truck or out the fender well?
05 4x4 SE~
Performance Mods:
Exterior Mods:
Old 08-30-2006, 09:00 AM   #5 (permalink)
gixxer0.6g's Avatar
How about a 17x10 with a +31 offset and 285/70r17 tire with a prg mini lift installed?
05 4x4 SE~
Performance Mods:
Exterior Mods:
Old 08-30-2006, 11:04 AM   #6 (permalink)
d0va's Avatar
does wheels are nice but like swarren mention you might want to stay away from the 10" width rim, listen to the man he knows about wheels and tires...
Pm for a Signature Request
Check out my Photoshop Signature Album
d0va is offline   Reply With Quote
Old 08-31-2006, 06:10 AM   #7 (permalink)
Hey Flash I know your getting bounced around but you will get a better response if you start a thread on this subject! Do you know how to start a thread? If not I can help you out. BTW nice looking ride I wish I had those mirrors!
Now Gone but still Love em----------------07 2500 HD silverado 4 door
Old 08-31-2006, 06:22 AM   #8 (permalink)
Yes Please thanks,
flash_pin is offline   Reply With Quote
Old 08-31-2006, 06:26 AM   #9 (permalink)
Originally Posted by flash_pin
Yes Please thanks,
Yes you need help? or yes I will start a new thread?
Old 08-31-2006, 06:28 AM   #10 (permalink)
Both Please... Please see the home thread Titan Wheels, Tires & Brakes. I think I started it. Not sure.
Old 08-31-2006, 06:29 AM   #11 (permalink)
PM sent Flash!
Sorry for the hijack back to topic!!
Wheel and Tire Size Help YZmoto125 Titan Parts & Accessories 3 05-16-2006 07:04 PM
Tire and Wheel help? DWBTITAN421 Florida Forum 0 12-31-2005 06:46 AM
Tire Choices for OEM 17s TITANTX Titan Wheels, Tires & Brakes 4 12-02-2005 02:47 PM
Stock Off Road Tire size, not many choices? burp43 Titan Wheels, Tires & Brakes 4 05-16-2005 10:21 AM
A little wheel and tire help, please. The_Man Titan General Discussion 2 04-04-2005 05:48 AM
