Old 09-03-2006, 11:42 AM   #1 (permalink)
Send a message via AIM to ibbodyboarder Send a message via MSN to ibbodyboarder
You're 2 cents on these 18 inch tires??
Looking to put on my 18x9 MB Smoothies
http://cgi.ebay.com/ebaymotors/285-6...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/4-NEW...04743256QQrdZ1
ibbodyboarder is offline   Reply With Quote
Old 09-03-2006, 12:15 PM   #2 (permalink)
NorCal 4x4's Avatar
Re: You're 2 cents on these 18 inch tires??
The Nittos are 31.38" dia. and the Toyos are 31.48" dia so they might be a little short for you, depends on the look you are after. Titans will take a 33" dia. tire stock.
NorCal 4x4 is online now   Reply With Quote
Old 09-03-2006, 12:21 PM   #3 (permalink)
yea. I want some tires where it's just thick ENOUGH. Not too huge and not too small and on a 2 inch lift. I'm somewhat unfamiliar with 33 inch, 32, 31 inch, etc.. What would a 33 inch be? i.e. 285/75/18
Old 09-03-2006, 01:12 PM   #4 (permalink)
what about these? There's no pictures but check the specs and tell me what you think
http://www.1010tires.com/tire.asp?ti...%2FT&pc=362450
Old 09-03-2006, 01:18 PM   #5 (permalink)
NorCal 4x4's Avatar
A 285/75/18 would be an 11.5" wide 34.8" diameter. Probablly need a lift, but it would be very hard to find this size. Not very many 75 series tires. Mostly 60 and 65 for the 18" wheels.
A 285/65R18 would be an 11.5" wide 32.5" diameter.
A *305/65R18 would be a 12" wide 33.7" diameter. Might need a level kit for this one, or at least stock rims and stock offset.
* A new BFG AT KO size.
What's the rim size and offset you ended up with?
Old 09-03-2006, 01:29 PM   #6 (permalink)
18x9 with a 10mm offset Mb Smoothies. Thanks for all this info. I"m use to low pro tires but I'm getting a little bit into lifted trucks now and I'm looking to find some NICE size tires with a PRG 2 inch lift.
Old 09-03-2006, 01:45 PM   #7 (permalink)
NorCal 4x4's Avatar
You might have to do the pinch weld mod but since those 9" wide rims have similar to OEM backspacing, (+12 would be the same and +10 is so close), maybe not. I'd go for the BFG AT in the LT305/65/18.
Oh I figured out what the tire calculators do, but the real size very among tire size even for the same model as an example the BFG AT LT315/70/17 should be 12.4" wide, but their specs say 12.0". And 12.0" is what a 305/65/18 is. And I've seen some LT35x12.5 tires that were over 13" wide, so it pays to read the specs. But here is the tire calculator formulas which will give you ball-park:
Example for 285/65/18:
285 is the width in mm. 285/25.4 = 11.22"
65 series is the percentage of width to side wall 0.65 x 11.22 = 7.29"
Add side wall + 18" rim diameter + side wall = tire’s diameter = 32.59"
Old 09-03-2006, 02:03 PM   #8 (permalink)
Funny. I checked Discount, Tire Rack and it showed up nothing on the size you told me to go with.
Old 09-03-2006, 02:21 PM   #9 (permalink)
hooligan's Avatar
discount and tire racks web sites suck for offroad size tires!!!! check 4wheelparts.com for tire sizes but i don't recommend buying from them! where you located? Imperial Beach?
Old 09-03-2006, 02:39 PM   #10 (permalink)
Yea. I THINK there is an ORW in San Ysidro. Know any shops around my area or just in SAN DIEGO that sell some with reasonable prices?
Old 09-03-2006, 02:46 PM   #11 (permalink)
NorCal 4x4's Avatar
San Diego, CA http://www.discounttire.com/dtcs/sea...05&ar=65&rd=18
Old 09-03-2006, 07:34 PM   #12 (permalink)
thanks for the link
Need ideas on what 18 inch tires to get. HELP!!! ibbodyboarder Titan Wheels, Tires & Brakes 5 08-31-2006 09:48 PM
FS 17'' inch tires" aguilar82082 Buy/Sell 6 09-09-2005 05:52 PM
17'' inch tires aguilar82082 Buy/Sell 0 06-12-2005 07:58 PM
do u think 34 inch tires will fit on a stock titan ? graytitan4x4 Titan Suspension 14 03-20-2005 05:10 PM
What size 18 inch tires to run? zmydust Titan Wheels, Tires & Brakes 9 10-13-2004 08:23 PM
