Old 09-10-2006, 12:02 PM   #1 (permalink)
FlimFlamMan's Avatar
Tire Pro Advice Needed.
I'm wanting to get some beefier tires for my stock steelies. Wheel size is 17 x 7.5.
Anyone here beefed their stock steelies up?
I have PRG's 2.5" front lift so I have room to grow.
I'm not sure exactly what my options are. Thanks in advance for your advice.
Flim
2007 WRX TR (5 speed)
Stage I
The Titan will be missed....
2005 XE CC 4x2
QX56 OEM Wheels
Uprev Tuned
Old 09-10-2006, 03:33 PM   #2 (permalink)
NorCal 4x4's Avatar
Re: Tire Pro Advice Needed.
Flim
A lot of people are running BFG AT KO in the LT315/70/17 (34.5 x 12 x17) on those and the off road 17 x 7.5 +30mm offset rim with just PRG level kits.
About 10 pounds more than the BFG AT KO LT285/70/17 (32.8 x11.5), so for me to change to 315s it's like tossing 400 lbs. into the truck bed as far as gas mileage. With your XE tires which are fairly small right? - it would be even worse.
Old 09-10-2006, 03:53 PM   #3 (permalink)
Sounds like a LT285/70/17 would be the way to go then.
I wish I could get a taller tire to help fill in the wheel well a little more, but it sounds like that would require a larger rim.
Thanks, swarren1.
Stage I
2005 XE CC 4x2
QX56 OEM Wheels
Uprev Tuned
Old 09-10-2006, 04:13 PM   #4 (permalink)
NorCal 4x4's Avatar
Thanks, swarren1.
If you don't tow or haul big loads, or off road hard, even the 8 ply D rated BFG AT KO LT285/70/17 might be overkill. Don't get me wrong. I like mine, they are very quite, look good, big pot holes are not a worry at all, but the potential for real fuel savings, and higher acceleration performance of the 12 pound lighter Revo AT should be considered.
BFGoodrich All Terrain A/T KO LT285/70/QR17 D Q=99 mph, payload = 3195 lbs. at 65psi,
tread depth = 16/32”, Weight = 55 lbs.
The Revos in the same size are 12 pounds less the the BFG, which is like having 480 pounds less for your Titan to push.
Bridgestone Dueler A/T Revo P285/70/TR17 T=118 mph, payload = 2833 lbs. at 44psi,
tread depth =11/32”, Weight = 43 lbs.
Kumhos are another passenger AT in this size.
Kumho Road Venture AT KL-78 P285/70 SR17 S=112 mph, payload = 2832 lbs. at 44psi,
tread depth = 14/32”, Weight = 45lbs.
Advice needed for '06 w/RF & backseat DVD Inspector_Gadget Titan Visual & Audio Discussion 3 08-24-2006 09:32 AM
I want to buy a Titan. Advice needed! Billy Shears Titan General Discussion 30 02-15-2006 08:10 AM
Advice Needed K&N or Volant Vector Titan Performance Modifications 15 06-12-2005 09:32 AM
Handgun Advice Needed. MXTitan Hunting / Fishing 47 09-26-2004 01:11 PM
Advice regarding wife needed! dd564 Titan General Discussion 13 03-09-2004 01:26 PM
