Old 09-25-2006, 08:57 PM   #1 (permalink)
etalian2005's Avatar
Send a message via AIM to etalian2005
tire sizes
if i want to put a 22 x 10 rim inside of a 35" tire. what is the metric tire size that i need would it be 305/55R22??? thanks
etalian2005 is offline   Reply With Quote
Old 09-25-2006, 10:01 PM   #2 (permalink)
NorCal 4x4's Avatar
Re: tire sizes
That would work. 35.2" x 12 but rim should be 0mm offset for a 10" with stock 5.5" backspacing.
The Kumho AT in a LT325/50/22 would also work, 34.8" x 12.8" (by calculator). You might even want a 5" backspacing (-12mm offset), for tire to clear the knuckle more, but more likely to rub inner fender at full steering lock as you move the wheel out.
Pirelli makes an ATR 325/55-22 that is 36 x 12.8"
Search for sizes at Tirerack.com
http://www.tirerack.com/tires/SearchTires.jsp
NorCal 4x4 is online now   Reply With Quote
Confused on tire sizes 05TexasTitan Titan Wheels, Tires & Brakes 3 09-24-2006 10:49 PM
? on tire sizes... Blackin Off-Topic Discussion 5 08-11-2006 02:04 PM
? about 20" tire sizes jungle jim Titan Parts & Accessories 9 04-05-2006 10:30 AM
Tire sizes HVACman Titan Wheels, Tires & Brakes 8 02-19-2005 07:46 PM
tire sizes? bigd2115 Titan Interior Discussion 5 08-09-2004 07:29 AM
