Old 12-11-2006, 12:20 AM   #1 (permalink)
Titan671's Avatar
Send a message via Yahoo to Titan671
Steering Vibration on 22" rims
Hello Forum,
I'm fairly new here and this is my first post.
I recently purchased 22" Centerline Rims for my 04 Titan. Now I have steering vibration around 45 mph. I had the wheels balanced three times, but the vibration is still there. I took it back today and the shop installed aluminum center hub adapters to fill in the gap from the wheel hub to the rim.
Took it out...and still there is vibration! I spoke to the shop tech and he believes it may be the rotors or the tires themselves.
Im taking the Titan to the Nissan dealer tommorrow to have the rotors checked or replaced. If that doesn't help, could it be the tires? The tires are not name brand tires, so my guess is, it could also be the tires. The tires are 305/40/22. Any other ideas or tips...
Thanks
Titan671 is offline   Reply With Quote
Old 12-11-2006, 03:31 AM   #2 (permalink)
Re: Steering Vibration on 22" rims
are you lifted or lowered? maybe check pinion angle?
Stock motor
blwn sss is offline   Reply With Quote
Old 12-11-2006, 03:38 AM   #3 (permalink)
BKW
Did they spin balance the wheels? Or just put them on the changer and balance them there. The problem didn't exist before...so I doubt it's the rotors. If someone dropped one of those wheels, it's now out of balance...or the wheels were out of whack before they were installed.
Yes, the driveshaft is now at a different angle...but I doubt that's the root of the problem.
It's the wheels.
BKW is offline   Reply With Quote
Old 12-12-2006, 12:27 AM   #4 (permalink)
scarface805's Avatar
did they properly torque the wheels? did they match mount the wheels to the tires. have them ck these basic things.
scarface805 is offline   Reply With Quote
Old 12-12-2006, 06:17 PM   #5 (permalink)
Titan671's Avatar
Got the truck back from the shop. Their fix, they changed all four rims and installed Nitto tires. They said the vibration had stopped, but when i took it home, I could still feel the vibration. I had my wife drive the titan and followed close by, I could see the rims wobble as if the rims were not installed right. I took it home and removed the rims and installed them as flush as I could get them with the rotors. I drove her out and again you could feel the vibration and visually see that the rim is NOW slightly wobbling. I guess it could be the lug nuts not properly seating in. What else could it be????
Old 12-12-2006, 11:47 PM   #6 (permalink)
titan814's Avatar
go to DISCOUNT TIRE and get them ROADFORCE ballanced. it will make it all better. i had this same problem with my 22's. now the problem i am running into is my inside of the tires are wearing faster then the outside.
400hp LS6 CTS-V
titan814 is offline   Reply With Quote
Old 12-13-2006, 12:39 AM   #7 (permalink)
hmm are your wheels still loose once you tighten the lugs? maybe your lug nuts are to short?
Stock motor
Old 12-13-2006, 02:20 PM   #8 (permalink)
Titan671's Avatar
Finally!
Thanks for all your advise. I went to another wheel shop and told them my problem. The owner suggested that I change the lug nuts with the ones with a sleeve because the ones that came with the Centerlines didn't appear to fit the holes. They tooks off the rims and re balanced them. To my suprise, all four rims were off balanced! The rims were also low in air, about 20 psi each! They balanced and mounted the rims and I took a test drive. Well, what do you know, no vibration!
Today, I will be returning to the shop where I bought the rims and slap them with the receipt for the re balance. To add, I'll probably let the owner now that his employees need more training on how to balance and "put air" on a tire.
The tire I have now are 305/40/22. Any recommendations for the 305/45/22. The sidewall is alot taller than the 40 s and it fills in the gap between the fender.
Again, thanks alot guys.
Vibration in steering wheel khouston Titan General Discussion 24 12-09-2006 07:33 PM
Vibration in Steering Wheel khouston Titan General Discussion 11 12-06-2006 05:20 PM
Steering Wheel Vibration after new brake fix KATM Titan General Discussion 0 10-04-2005 06:12 PM
steering wheel vibration dilleyoshemp Titan General Discussion 7 09-08-2004 11:00 PM
