Old 12-15-2006, 12:03 AM   #1 (permalink)
355/50/20 kumho all terrain
hi guys just wanted to know if any1 has tried this tire size on just a leveling kit. kumho says it comes out to a 33.9. i wanted to run these but didn't know if it would rub. any advice would be much appreciated.
johnwoo is offline   Reply With Quote
Old 12-15-2006, 06:42 AM   #2 (permalink)
CVTITAN's Avatar
Re: 355/50/20 kumho all terrain
Check with Yellowmantis. He was running 35 Kumhos with a leveling kit.
BIG WHITE TRUCK...
CVTITAN is offline   Reply With Quote
Old 12-15-2006, 07:15 AM   #3 (permalink)
Yellomantis's Avatar
What is the width on those?
www.myspace.com/yellomantis
Old 12-15-2006, 07:46 AM   #4 (permalink)
rod_b's Avatar
355 is about a 14" wide tire. My guess it that they would rub pretty bad
8.04 K11 CC LE 4X OR BT PRG'd
rod_b is offline   Reply With Quote
Old 12-15-2006, 07:51 AM   #5 (permalink)
^^^yeah, what he said^^^
Old 12-15-2006, 08:25 AM   #6 (permalink)
CVTITAN's Avatar
Second that..
BIG WHITE TRUCK...
Old 12-15-2006, 09:57 PM   #7 (permalink)
NorCal 4x4's Avatar
Here is a case where you want negative offset, to clear the steering knuckle or spindle, and in a big way.
We're talking a 4" backspacing, (instead of our OEM 5 1/2"), and probably a 10" width rim with a -40 mm offset. These rims with stick out 4" more than the Off Road pkg. rims! Of course now they will probably rub at the pinch weld big time.
Silver '04 Titan SE Crew Cab 4x4 w/E-LOCK® - Born on 05/18/04 in the USA ... 33.5" Toyo M/Ts;
NorCal 4x4 is online now   Reply With Quote
Kumho KL78's gixxer0.6g Titan Wheels, Tires & Brakes 4 03-31-2007 10:13 PM
Kumho KL78's gixxer0.6g Titan Wheels, Tires & Brakes 19 03-30-2007 09:36 PM
Kumho Tires gixxer0.6g Titan Wheels, Tires & Brakes 5 08-07-2006 06:51 AM
Kumho tires KYDeepwater Titan General Discussion 9 09-28-2005 01:01 AM
Mud Terrain vs. All Terrain Tires MXTitan Titan General Discussion 11 08-16-2004 10:07 PM
