Old 12-19-2006, 08:03 PM   #1 (permalink)
i<3mytitan's Avatar
Send a message via AIM to i<3mytitan
37s vs 35s
hey everyone, i'm debating as to whether or not to go w/ 37s after the new year, just had one question:
I expect there to be added stress on the drivetrain, but would that be alleviated w/ the new gears that should be available? I already expect decreased braking, due to the weight of the tires, but i don't know what to expect with 37s and the new gears coming out...input greatly appreciated.
Thanks a lot
No more sig for me
i<3mytitan is offline   Reply With Quote
Old 12-19-2006, 08:35 PM   #2 (permalink)
kartman's Avatar
Re: 37s vs 35s
The gears will help with acceleration but the wear and tear wont really change, its still a lot more rotating mass and unsprung weight.
Rebar Wrangler
Old 12-19-2006, 09:18 PM   #3 (permalink)
i<3mytitan's Avatar
Re: 37s vs 35s
Cool, thanks a lot. 37s are out of the question, i don't need any unecessary wear/tear.
No more sig for me
Old 12-20-2006, 01:18 AM   #4 (permalink)
NorCal 4x4's Avatar
Re: 37s vs 35s
Some 35s weigh more than some 37s.
Both the 37" BFG AT KO and the BFG MT KM, only weigh 65 lbs. where the 35" Toyo M/Ts weigh in at 83 lbs., (for the 12.5" x 17" sizes).
With one of those really tall spindle lifts, plus c.o. and spacers to bring them up greater than 8", the BFG 37s would look great, and because of their lighter weight, the extra diameter would not be any worse stress than a Toyo 35.
Btw, the BFG AT is only 36" dia. and the BFG MT is only 36.5" dia.
Old 12-24-2006, 05:52 PM   #5 (permalink)
pgthe1's Avatar
Re: 37s vs 35s
Yup... I noticed a big difference from the 35's Toyo M/Ts I had and my BFG 37 AT’s I have now... The toyo's are pig's in weight... but are just as quite as the BFG AT’s.
pgthe1 is offline   Reply With Quote
Old 12-24-2006, 06:44 PM   #6 (permalink)
BlingAlong06's Avatar
Send a message via AIM to BlingAlong06
Re: 37s vs 35s
Go 37s !!!
2006 SE CC 4x4 OR BT
AEM BruteForce CAI
Airraid TBS
Banks exhaust
2* TA
TB-Bypass
Leveled out
Smoked tail lights
Dark tint(Real Dark!!!)
Motometal 951s
Nitto Terragrapplers 325/60/18
BlingAlong06 is offline   Reply With Quote
Old 12-24-2006, 09:09 PM   #7 (permalink)
rcantu's Avatar
Re: 37s vs 35s
if they fit, do it.
pics of the Titan
Old 12-25-2006, 06:21 AM   #8 (permalink)
i<3mytitan's Avatar
Re: 37s vs 35s
well, I found some Kumho M/Ts with a pretty nice tread pattern, and in the 37x1250x20, they weight around 84lbs; toyo M/Ts come in at 84ish, while the 37" toyos weight roughly 95lbs. So I guess i'll be getting the Kumhos around the same time the new gears come out.
No more sig for me
Old 12-25-2006, 11:28 AM   #9 (permalink)
Aquaholic's Avatar
Re: 37s vs 35s
If you are worried about weight and tearing up stough don't do 37s. Look around and compare tires. Don't do 325 65 18s either they weigh a ton. I am buying a set of Dunlop Mud Rovers and they are rated at 56lbs each. Only 9 lbs over stock and 11 lbs lighter then BFG muds and a/ts
2007 White with Charcoal SE CC 4x4 with off road, tow, SE popular with bench, and utility with bed extender
Mods to date:
6" Procomp Stage II lift, CST Sway bar endlinks, 35x12.5x17 Procomp Mud terrains, 17x8 Moto Metal 954s, Smittybuilt stainless nerf bars, Chrome mirror caps, Color matched Bushwackers, Leer 700 Toneau cover, T Rex 1pc grille, Custom FlowMaster DeltaFlow 50 series dual in single out muffler, Injen powerflow intake, JVC Kw-avx800 7" in dash dvd, 7" DEI wide screen headrest monitors, Sony Xplod 2x250 amp, Infinity Reference 6 1/2" in rear and 6"x9" in front, Prodigy brake controller, Ventshade door sill protectors
RIVER TRASH C.O.R.R. Junky
Aquaholic is offline   Reply With Quote
