Just got my wheels & tires put on today, and my tire guy told me I should get the hub centric rings for the wheels. He said I might have problems with vibrations in the future. Do I really need them?
And is there any truth to Weld Racing wheels filing chapter 11? If so, how am I going to get these?
I have the "No Fear" Weld Dune 6's. 17x8.5 with 4.5 BS and BFG 315/70R17 AT KO tires. They rub bad @3/4 turn. Hopefully the pinch weld mod will fix this though!
Sport Truck mag has a page on it. Last year they bought the Boyd Coddington wheel division and how they have acquired Weld, as kartman has said. They should have quite the selection now, although the brands are to remain separate and still carry the name they were designed under.
If you can't get them to stop rubbing send them my way
To answer your question just make sure the wheels are seated evenly on the hub before tightening them down, should be fine w/o the rings. The type of lug nut you need depends on the wheel, if my memory serves me correctly (I'm too lazy to look) most aftermarket wheels require conical lug nuts.
__________________ When someone smiles at me all I see is a chimpanzee begging for its life.
