Old 12-26-2006, 11:00 PM   #1 (permalink)
sound from the brakes
I was wondering if this is normal. On uneven dirt and under a quick stop where the truck tends to slide a bit I get a sound from what I think is coming from the brakes. It sounds as if the brake is grabbing but as the truck bounces or slides across the terrain it forces the wheel to spin and makes a noise. The noise sounds kinda like a grind/popping. This only happens when I am on it pretty good and need to come to a stop fast on uneven dirt. Could this be the ABS?
007titan is offline   Reply With Quote
Old 12-26-2006, 11:03 PM   #2 (permalink)
Yellomantis's Avatar
Re: sound from the brakes
Most likely yes. It only happens on soft loose surfaces? Mine makes a quick gaaaa gaaaaaa gaaaaa sound when the ABS kicks in while off roading.
www.myspace.com/yellomantis
Old 12-26-2006, 11:05 PM   #3 (permalink)
yeah that's what I thought. Do you know of a way to easily switch the ABS on and off?
Old 12-27-2006, 06:26 AM   #4 (permalink)
There are some connections at the brake pedal, but I think they turn off the taillights also. Somebody posted a way to do it with a switch under the hood. I think they call it burn out mod if you search. Also, if you have a VDC off button, that should be turned off when offroad.
06 brakes different than late 05 brakes??? CJ3FLYR Titan General Discussion 2 02-19-2006 04:51 PM
Sound brave781 Titan General Discussion 1 02-03-2005 03:38 PM
Hemi Brakes vs Titan Brakes Bayou Titan Titan General Discussion 4 02-01-2004 06:45 PM
