Originally Posted by sdcantrell
I need to know if american racing chamber wheels in 17 x 9 will fit on a leveled 4x4 without any rubbing.
Thank You.
They will likely rub, because they will stick out 2.5" more than the OEM 17 x 7.5", (an inch and a half wider, and an inch less backspacing than the OEM 5.5".
Big tires will make it worse but even a stock size tire will likely rub at full steering lock, sticking out this much.
Pinch Weld Mod I think it is done on the front wheel-well only, to the rear/mud flap side.
You may also have to remove your mud flaps with these rims.
