Old 01-05-2007, 05:41 PM   #1 (permalink)
Gonpostal's Avatar
Everyone with 325/60 or 65 (Question)
How many PSI are you running on your tire and brand please.
Gonpostal is offline   Reply With Quote
Old 01-05-2007, 05:53 PM   #2 (permalink)
titanmann's Avatar
Re: Everyone with 325/60 or 65 (Question)
35 psi - Nitto Terra Grappler 325/60
titanmann is offline   Reply With Quote
Old 01-05-2007, 06:15 PM   #3 (permalink)
NorCal 4x4's Avatar
Why do you want to know? The pressure depends on not only the tire but what you are doing with it at the time.
For their maximum load rating, they need to be at their maximum inflation, (listed on the sidewall), which varies by the particular tire. Most passenger P-rated tires range between 35 and 44 psi, max. Most LT tires range from around 55 to 83 psi max.
At 35 psi the OEM off-road pkg. P-rated BFG Rugged Trails have a higher load capacity than the LT285/70/17 BFG AT KO tires of the same size. But the BFG AT KO at 65 psi have a much greater load capacity.
Old 01-05-2007, 08:21 PM   #4 (permalink)
Gonpostal's Avatar
Well I just got my 35s and I was wondering what everyone runs daily driven, by the way I said people with 325/65 or 60 not 285/70 (dont worry its not a smart remark or any way to offend you)
Old 01-06-2007, 01:51 PM   #5 (permalink)
NorCal 4x4's Avatar
I guess you don't get the point of my post. It doesn't matter what everyone else is running, because it depends on the application, (which in your original post you failed to mention):
Now that we know your application, what brand, size, and model are yours? That is what really matters. Is there something about your new tires bothering you? i.e. too rough, noisy, etc.
The brand, model, and size of the tire and if it is a P rated or LT version also matter. Not a smart remark either, but this is the "Titan Technical Discussion Area". The things I pointed out in my post were applicable to 325/65 or 60 tires. 285/70 were used to make a point on the importance of proper psi for the particular tire's load and application.
Permanent brake fix question, rotor question. SWTXTITAN Titan General Discussion 4 08-06-2005 05:44 AM
