Old 02-17-2007, 10:11 PM   #1 (permalink)
need advice on tire rubbing
just put on some 305/55/20 nitto all terrain tires on my 4x4 titan. i previously had 295/50/20 hankook tires on. i didn't realize that nitto tires were so freakin big. don't get me wrong. i love them. they make the truck look more bad ***. just a slight problem. they rub a little when full steering lock to either side. was wondering what others have done who have this same problem or would love some advice. i am thinking of shaving the plastic inner fender cover or/and remove the front mudflaps. not sure what to do. after a few months, once the tire wore down, prolly wouldn't be a problem but def. rubs when i turn the steering all the way. any suggestions or info would be greatly appreciated. thanks, titanrookie
05' black,LE, CC 4x4 offroad w/bigtow
dvd, nav, sunroof with graphite leather interior, leer tonneau cover, bug shield, 20" kaotik chrome rims, magnaflow dual exhaust, train horn, aem brute force cai.
titanrookie is offline   Reply With Quote
Old 02-18-2007, 03:10 AM   #2 (permalink)
Brundy's Avatar
Re: need advice on tire rubbing
Many have removed their mud flaps. Also, behind the fender liner is a pichweld that can be trimmed or bent over for added clearance.
Brundy is offline   Reply With Quote
Old 02-18-2007, 08:21 AM   #3 (permalink)
danshipley26's Avatar
get a body lift
danshipley26 is offline   Reply With Quote
Old 02-18-2007, 08:42 AM   #4 (permalink)
Get a mini-lift from PRG and take off the mud flaps...
2005 CC 4x4 SE
AKA
Chunky Ass Whore
All Time Favorite TitanTalk Quote (in response to what type of Gasoline is best):
I personally prefer whatever's cheap. I'd club baby seals to death and squeeze oil from their limp little bodies if I could save a buck - Mr B
chunko is offline   Reply With Quote
Old 02-18-2007, 08:46 AM   #5 (permalink)
baseballfanz's Avatar
Pinchweld mod should be fine and don't cost you nothing except your times.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 02-18-2007, 11:29 AM   #6 (permalink)
TitanHigh's Avatar
go with the mini lift.
2005 Titan Smoke Crew Cab LE
9.5 inches of suspension lift
FOX Coil-Overs Up Front
FOX 2.5 shocks and Air-Bags In the Rear
3 inch Boddy Lift
Riding on 18's with 37's soon
TitanHigh is offline   Reply With Quote
Old 02-18-2007, 11:58 AM   #7 (permalink)
i have the level kit on the front already but still rubs. what do you guys think about me just trimming the plastic inner liner. in my haste to get nitto tires, i didn't realize that they came in the 305/50/20 size. i could just kick myself. i have only had the tires on for two days, but im sure i am stuck with them now. thanks for the replies guys.
Old 02-19-2007, 08:01 PM   #8 (permalink)
i just realized that only the left front tire rubs at full wheel turn. however, the right front just barely squeeks by without rubbing. why is this? any thoughts. bought the tires at americas tire co. they said i might be able to bring them back and put on the 305/50 instead of what i have. i have the 305/55 terra grapplers now. i just bought them a few days ago. any opinions on the slightly smaller tires. i know they won't rub.
Old 02-19-2007, 09:40 PM   #9 (permalink)
remove liner, do pinch weld mod....either grind off weld or cut. I grinded mine down as well as the area on the bottom where it curves into where the mud flaps were as well. I removed the mud flaps too. I have no issues now. I have the Nitto 325/60/18s
LAfirefytr is offline   Reply With Quote
Old 02-19-2007, 11:12 PM   #10 (permalink)
i can either cut the inner plastic fender or take it out entirely. however, do i really have to do anything to the pinch weld. not sure why i would have to grind it down. the tire just barely rubs the plastic inner fender and mudflaps. would it suffice if i just cut a small section of the plastic fender out and remove the mudflaps. do you guys think that would be ok. not sure about this pinch weld thing. thanks for all your replies and suggestions.
Old 02-28-2007, 10:26 PM   #11 (permalink)
Mine only rubs on the left side also. Just when i reverse left. I trimmed the plastic which only made it worse, as it exposed the metal pinch which catches the tire even more. Your going to have to remove some material from the pinch. There is plenty of information on this, just do a search.
bigtit is offline   Reply With Quote
do 20's fit without rubbing? titanmike Titan Wheels, Tires & Brakes 9 05-06-2007 12:00 PM
Need Tire advice/opinion Gooseblitz Titan Wheels, Tires & Brakes 4 02-19-2007 05:44 PM
Tire Pro Advice Needed. FlimFlamMan Titan Wheels, Tires & Brakes 3 09-10-2006 04:13 PM
Tire Rubbing? triplet_2004 Titan Performance Modifications 2 08-01-2005 02:59 PM
Rubbing Not His Titan Titan General Discussion 7 03-18-2004 09:34 PM
