Black wheels - Nissan Titan Forum
Old 04-07-2007, 11:00 AM   #1 (permalink)
iTrader Score: 0 reviews
Black wheels
Does anyone make a black wheel in a 17 or 18 that doesnt stick out of the fender well or maybe only an inch. I have a leveling kit and want to put 33in tires on a set of black wheels that wont stick out if the wheel well more thatn an inch. Most of the wheels i have seen stick out 2 or more inches. My ideal wheel would be the moto metal 951 in black but they seem to stick aout more than an inch from the fenders wells. Correct me if I am wrong. Any ideas? thanks
wssboard18 is offline   Reply With Quote
Advertisement
Old 04-07-2007, 11:45 AM   #2 (permalink)
Yellomantis's Avatar
iTrader Score: 8 reviews
Re: Black wheels
Good luck on your search. I was in the same predicament a while ago and I finally settled on a set of 17" AR Mojaves.
When these are released, they should fit your needs...
They will be available in a 17x8.5 with 5 3/8 BS.
2010 Dodge Ram Power Wagon
ICON sponsored, going to SEMA 2011, lots of mods
2011 Dodge Ram Quad Cab Sport
Ground Force 2/3 drop, 24" BOSS 330's, true dual exhaust with 11" Magnaflow muffler and x pipe, Volant intake
2007 Nissan Xterra Off Road
PRG Mini Lift
JBA Cat Back
K&N Drop In
CB Radio
Before you criticize someone, walk a mile in their shoes.
That way, when you do criticize them, you're a mile away, and you have their shoes.
Old 04-07-2007, 11:47 AM   #3 (permalink)
NorCal 4x4's Avatar
iTrader Score: 4 reviews
Re: Black wheels
edit: ^Beat me to it. Lol That one might work^: It's 8.5" wide. Thug with Teflon® (Series 3991)
1-piece black Teflon painted alloy.
American Racing Thug
Has +15mm offset and 5 3/8" backspacing, but not sure on the hub size, (06-on GM Truck)??
3991-78538A 17x8.5 15 5 3/8 6-5 1/2 06-on GM Truck
Here is one from Procomp ... Series 7005 CAST-BLAST™ FINISH.
It has 4.5" b.s. but is 8" wide so will stick out an inch less than the Moto Metal 951 9" wide rims with the same b.s.
7005-7838 (hub centric ... probably GM?) 17x8 6x5.5 0mm 4.5" 2200lbs 25lbs
7005-7883 (lug centric) 17x8 6x5.5 0mm 4.5" 2200lbs 25lbs
And a more off road appearing rim, the Series 7089 CAST-BLAST™ FINISH ... here.
7089-7838 (hub centric ... probably GM?) 17x8 6x5.5 0mm 4.5" 2200lbs 27lbs
7089-7883 (lug centric) 17x8 6x5.5 0mm 4.5" 2200lbs 27lbs
They have other models too.
Old 04-07-2007, 03:15 PM   #4 (permalink)
yscty's Avatar
iTrader Score: 5 reviews
Re: Black wheels
Here are a couple pics of mine, American Racing 17X8
It's a Titan!!!
yscty is offline   Reply With Quote
Old 04-09-2007, 11:50 AM   #5 (permalink)
Wallrat's Avatar
iTrader Score: 2 reviews
Re: Black wheels
AR 17x9 Chambers:
I've got feeler gauge fingers, torque wrench wrists, and a timing light eyeball!
05 SE KK 4x4
offroad, big tow, buckets, util.
$$$ stereo
Pro Comp 6", Dre's/Bilsteins, PRG Traction Bars
315/70 17 BFG AT KO on 17x9 AR Chambers
Wallrat is offline   Reply With Quote
Old 04-10-2007, 07:54 AM   #6 (permalink)
Re: Black wheels
i think the thug is a nice wheel
Masher500 is offline   Reply With Quote
Old 04-10-2007, 08:09 AM   #7 (permalink)
gadget74's Avatar
iTrader Score: 1 reviews
Re: Black wheels
Check out this page!
I have the helo maxx and really like them!
http://www.tiresdelivered.com/advancedSearch.php
Confucious say - Crowded elevator smell different to midget.
GoGoWhore©
Helo Black Maxx 17's, Nitto Teragrappler 295/70/17's, Jensen 7" indash DVD, 8" flip down monitor., 10" sub., Airbox Mod w/K&N Airfilter, NCD 2" Level Kit,
Painted black rear bumper, Black Powder Coated Perforated Alum Grill, Magnaflow, Memphis door speakers, 2 degree timing advance!
gadget74 is offline   Reply With Quote
Old 04-11-2007, 05:07 PM   #8 (permalink)
five13's Avatar
Re: Black wheels
I have the Pro Comp Wheels shown above in 17x9 w/ 35 x 12.5 this is it what it looks like..
five13 is offline   Reply With Quote
Old 04-21-2007, 02:32 PM   #9 (permalink)
Egan's Avatar
Re: Black wheels
Me too.
But I keep getting the run around everytime I try to buy them.
First it was "available mid-March".
I heard from some members here it would likely be April 1.
I went back to the shop on April 4 and they told me 1-2 months out.
Egan is offline   Reply With Quote
Old 04-21-2007, 03:41 PM   #10 (permalink)
vegastitan21's Avatar
Re: Black wheels
just paint yours son.
vegastitan21 is offline   Reply With Quote
Old 04-21-2007, 05:14 PM   #11 (permalink)
NorCal 4x4's Avatar
Re: Black wheels
Do you have a pic that shows them better?
If I end up getting 295mm or 305mm wide tires, I'll probably paint my off road rims in a flat/matt black, else bead blast them and clear coat them. But since the O.R. are only 7.5" wide I'll probably buy aftermarket 17s if I go with a wider tire.
Those have the 4.75" backspacing, (b.s.), so the 8" wide 4.5" b.s. model would stick out 3/4" less than yours. Also, the same tire on a Moto Metal 951 9" wide, 4.5" b.s. rim would stick out an extra 1/4".
Thanks for posting that pic as it is a great reference!
Old 04-21-2007, 07:21 PM   #12 (permalink)
Re: Black wheels
i can get sum. i really like mine cause they have a high gloss finish. im not a fan of the flat black wheels. looks like they have a bulid up of brake dust
Old 04-21-2007, 08:48 PM   #13 (permalink)
NorCal 4x4's Avatar
Re: Black wheels
Exactly ... Reminds me of the pride I felt when I first bought the Titan back in '04 before the brake fix.
I do think the matt black is more of an off road and gloss is more street.
IMO, your Titan wouldn't look out of place with a roll pan, so the gloss looks good. More pics of your rims would be cool ... to see the detail.
Advertisement
Granite w/ black or "black chrome" wheels what Titan Pictures & Media Post 6 04-28-2007 08:21 AM
my truck with black wheels joshthefirefighter Titan Wheels, Tires & Brakes 5 12-06-2005 12:53 PM
Looking for suggestions on Black 17' wheels Fat-Arrow Titan Wheels, Tires & Brakes 6 03-31-2005 11:55 AM
Black wheels anyone? rjspitz Titan Wheels, Tires & Brakes 10 01-09-2005 01:42 PM
SEO by vBSEO 3.3.2
