Old 04-27-2007, 05:39 PM   #16 (permalink)
Re: Got Nitrogen?
Simply put, because of the molecular properties of pure or almost pure nitrogen by itself vs. the toxic soup we regularly inflate a tire with, and using the coefficient n-1 to extrapolate the varied and extreme conditions of driving, you arrive at a mean value that approximates zero variability given any range of temperature change vs. the other stuff. Can I be any clearer?
kman is offline   Reply With Quote
Old 04-29-2007, 09:35 PM   #17 (permalink)
Send a message via AIM to Ridley
Re: Got Nitrogen?
Clear, but still bull****. There is absolutely no perceivable difference between the expansion, contraction, pressure change, etc, for use in tires between pure N2 and DRY air. Period. Doesn't matter what it's used for, racing, aircraft, whatever, still no difference. The only difference is that the pure N2 is DRY. Water vapor is the ONLY thing that makes any difference, and in street vehicle applications, it's negligable regardless. So, the bottom line is, N2 is a SCAM.
"The tree of Liberty must be refreshed from time to time, with the blood of Patriots and Tyrants." Thomas Jefferson
Ridley is offline   Reply With Quote
Old 04-29-2007, 10:51 PM   #18 (permalink)
Re: Got Nitrogen?
show me the math that supports it and i'll believe it.
Old 04-30-2007, 11:31 AM   #19 (permalink)
Re: Got Nitrogen?
np gimme a sec
Old 04-30-2007, 11:32 AM   #20 (permalink)
Re: Got Nitrogen?
[p+a(n2/v2)](V-nb)=nRT
V is the total volume
a is a measure of the attraction between the particles
b is the volume enclosed within a mole of the particles b = nAb',
n is the number of moles,
R is the gas constant
And using the established van der waals constants of:
% composition of air
N2=1.39 78.084%
02=1.36 20.947%
Ar=1.34 .934%
co2=3.59 .033%
You can see that at normal temperature fluctuations seen in tires, "air" and pure nitrogen will result in pressure variations of less than 1%. That would be the equivalent of ~1/2 psi at 50 psi
However, if you add a significant percentage of water vapor... with a van der waals constant of 5.46, you could see fluctuations of up to 5-7%, which is still absolutly irrelevant in a street car, but may have a slight disadvantage in a racing application where extreme temperature fluctuations in the tire occur and minute pressure variations have adverse handling effects.
SO, I'll reiterate.......Nitrogen is a scam. Most comercial compressors, have efficient air "dryers", so h2o vapor is not an issue. Now, if you have a hillbilly deluxe air compressor that has a tank full of water cause it's never been drained............N2 would be a good investment
The 20$ or so spent on the nitrogen scam, would be much better spent on an oil change
Old 04-30-2007, 12:04 PM   #21 (permalink)
CoeCEO's Avatar
Re: Got Nitrogen?
"Thanks to its larger molecules, nitrogen stays confined within the tire longer, and helps maintain tire pressure because it diffuses at a rate about 30 to 40 percent slower than oxygen."
Found it here: http://www.theautochannel.com/news/2...25/105870.html
This may answer questions: http://www.getnitrogen.org/pdf/print...%20Article.pdf
Or this article: http://www.getnitrogen.org/pdf/print...nician-feb.pdf
All of these say Nitrogen molecules are larger.... I guess Nuke is the only one doing the math correctly?
Oh well, I did it and it was free.
K&N Intake
Magnaflow 18"
AVS Low-Pro Vent Visors
Lund Chrome Sidesteps
4-Piece Billet
Autobot Emblems
CoeCEO is offline   Reply With Quote
Old 04-30-2007, 02:34 PM   #22 (permalink)
Re: Got Nitrogen?
They are wrong. Nitrogen and oxygen are both diatomic molecules. Oxygen is actually the larger of the two and diffuses slower. Even if ALL the trace gases leaked out, thats still only 1% of the volume, or pressure, hence .5 psi. Simple science, and alot of sheeple falling prey.
Old 04-30-2007, 03:09 PM   #23 (permalink)
Re: Got Nitrogen?
N2=1.39 78.084%
02=1.36 20.947%
Ar=1.34 .934%
co2=3.59 .033%
Ok, i like your math, you win. Question - given the choice, if nitrogen was free, would you choose it over air?
Old 04-30-2007, 03:12 PM   #24 (permalink)
helomech's Avatar
Re: Got Nitrogen?
I have free nitrogen at work, we have to use it on the helicopters, and I have never used it on my tires.
Old 04-30-2007, 07:07 PM   #25 (permalink)
Re: Got Nitrogen?
I wouldn't care one way or another to be honest. I would contaminate it air from my compressor eventually anyways, lol. As I air down occassionally for offroad, it wouldn't last long regardless. I just hate seeing people get ripped on snake oil, so I tend to speak up. Can't beat free though..............can barely find air for free these days, lmao
Old 04-30-2007, 07:20 PM   #26 (permalink)
Carbeaux's Avatar
Re: Got Nitrogen?
From Wikipedia:
Nitrogen molecules are less likely to escape from the inside of a tire compared with the traditional air mixture used. Air consists mostly of nitrogen and oxygen. Nitrogen molecules have a larger effective diameter than oxygen molecules and therefore diffuse through porous substances more slowly.[4]
The footnote being:
^ G. J. Van Amerongen. The Permeability of Different Rubbers to Gases and Its Relation to Diffusivity and Solubility. Journal of Applied Physics 1946, 17, 972-985. DOI:10.1063/1.1707667.
Just another source for consideration.
Hook 'Em Horns!
- Frank Zappa
Old 05-02-2007, 10:00 AM   #27 (permalink)
Nuke's Avatar
Re: Got Nitrogen?
Originally Posted by Carbeaux
From Wikipedia:
The footnote being:
Wow, so molecule size is not strictly a function of atomic weight? That is good stuff. Got to love wiki. I found another source that says basically the same thing. From the report referenced by wiki, Table 2, page 6, at 50 degrees, if you look strictly at solubility in natural rubber, oxygen is 0.106 and nitrogen is 0.060. That would make air 0.069.
Ignoring permeability, where nitrogen has even less of an advantage, what does that mean? Assuming your leakage through the tire wall is, say 10% per year with air. It's nowhere near that, probably closer to 1%. But just for argument's sake, 10% is 3 psig/year, then you could cut it down to 2.6 psig/year, for a savings of 0.4 psig/year using nitrogen versus air. At best.
Nuke is offline   Reply With Quote
Old 06-14-2007, 03:54 PM   #28 (permalink)
jgio's Avatar
Re: Got Nitrogen?
Just came from the dealer and they comp'd me all 4 tires with nitrogen, I can honestly say I feel the difference in the road. But all I do is Day to Day driving and haul some horses around. BTW only have OEM tires.
SERVING PROUDLY! PULLING DRILL SGT DUTY IN OKLAHOMA!
jgio is offline   Reply With Quote
Got Tires filled with Nitrogen. gratefullife Titan Wheels, Tires & Brakes 56 02-28-2007 07:54 AM
Nitrogen fill-up Howie Kaluha Titan General Discussion 4 11-23-2006 09:31 AM
Nitrogen for Tires Tx_flip Titan Wheels, Tires & Brakes 36 05-07-2006 07:55 PM
