Old 02-02-2008, 08:10 PM   #16 (permalink)
Re: Tire Size/Odometer/Speedo Correction...
Do not use the radar systems you see on the side of the road to check your speed those things are never very accurate.
My 08 Titan shows @3mph faster on the speed than it is actually going on stock tires.
If you go to a larger tire size your speed-o will be off by a %. So if the tire you put on is 10% larger then you will always be going 10% faster than what your speed-o reads. SO at 10mph you are traveling 1mph faster than what your speed-o shows and at 100mph you are traveling 10mph faster than what it shows.
There is also @ +/-3mph margin of error for the factory speed-o. Same with most GPS systems.
One of the reasons that police usually do not bother people traveling 5-10mph over the speed limit is that the margin of error of all the equipment involved falls within this range. Laser however is said to be very accurate.
Winder is offline   Reply With Quote
Old 05-02-2008, 09:34 AM   #17 (permalink)
I purchased the Hypertech In-Line Speedometer Calibrator from RealTruck.com for $206.99 shipped. (Use the coupon code SJ921) This was on my 08. It offeres tire/wheel size correction and gear ration correction. It was a pain in the arse to install. I had pull out the instrument panel to get the plug it connects to, but it worked. The tires I put on were wider but an 1 1/2" shorter so I was putting more miles on my truck than I was actually driving. But this fixed it and everything is reading correct according to my GPS.
ETx08Titan is offline   Reply With Quote
The Following User Says Thank You to ETx08Titan For This Useful Post:
CL 8 2WD (01-03-2009)
Old 05-02-2008, 09:57 AM   #18 (permalink)
Send a message via Yahoo to Cajunguy
Handy dandy calculator for changing your tire sizes:
http://www.dakota-truck.net/tirecalc/tirecalc.html
'04 Titan Galaxy LE KC 4x4
Off Road & Big Tow Packages
Build Date: 06/14/04
Buy Date: 06/25/04
Wade In-channel Vent Visors
PRG's Front Leveling Kit
P/A 3" Body Lift Kit
Bushwacker Fender Flares
Billet Grille
MagnaFlow Single Side Exit
Nitto Dune Grappler A/T (315/70/17)
Firestone RideRite Airbags
Cajunguy is offline   Reply With Quote
Old 01-25-2009, 12:58 AM   #19 (permalink)
i have found the best size calculator gives both the % and speed difference traveling at 60
Tire Size Calculator - tire & wheel plus sizing
2004 CC LE Smoke: Factory: Chrome Package, Utilitrack system, Bed Extender
Mods: Tinted Windows, Pro Comp Xtreme A/T 305/60 R18 on stock rims, PRG 2in Leveling Kit
Wants: Banks Exhaust, Banks CAI, 18x10 inch rims, Bull Bar /w 6inch driving lights, under seat storage, and whatever else i can afford
Tilldain is offline   Reply With Quote
Old 01-25-2009, 12:16 PM   #20 (permalink)
TitanBlue's Avatar
Anybody have a solid answer as to what Tire the Titan is calibrated to OEM? I know the XE is slightly smaller than the SE/LE Tires. I think the XE was a 31.8" or 31.6" tire. My current 265/70/17 seems dead on with GPS.
My greatest need, is to reset my Cipher for 0-60 MPH when I go to the track again. I'll change it to a 0-68 MPH or whatever, to get accurate 0-60 MPH ET with my Drag Radials. They are much smaller Diameter, about 28"
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG Street Traction Bars and Mini Lift Kit, UpRev Osiris Tuner 93 Performance Tuned, MB Razor Rims, Functional Hood Scoop, Custom Graphics ...
Old 01-25-2009, 12:49 PM   #21 (permalink)
titanss's Avatar
My 04 XE the speedo was set for the 265-70-18 (32.6" tall) stock tires were the 245-75-17 (31.5" tall) and the speedo was off by 3 mph. I got one of the Hypertech In-Line Speedometer Calibrator and set it for the 17's and the speedo was dead on.
2004 XE KC
Quickest UnTuned Titan: 13.900@96.67mph
The Following User Says Thank You to titanss For This Useful Post:
TitanBlue (01-25-2009)
Old 05-26-2009, 10:10 AM   #22 (permalink)
tywinter's Avatar
Originally Posted by TitanTech659 View Post
Also you can use the tire pressure sensors on some but not all aftermarket wheels. It depends on the hole that the valve stem goes in.
I have seen where someone strapped the senor to the inside of a wheel instead of the stem hole. You see any reason this wouldn't work universally for all wheels?
2003 350Z 6MT Brickyard Red couple of mods 1/4 mile at 13.2XX
2004 Titan Galaxy Black SE Crew Cab 4X4 Big Tow and Off Road Options
Flowmaster Exhaust, 2* Advanced Timing, Leveling Kit in Front, 1" Blocks in the Rear
tywinter is offline   Reply With Quote
Old 07-13-2009, 10:43 PM   #23 (permalink)
Hello everyone just purchased some 20" rims on 33" m/t toyo tires and my significant other says that she noticed an increase of speed down the highway today. IS HER FOOT HEAVY OR IS THIS NORMAL? 2004 se king cab 4x2
chuyb is offline   Reply With Quote
Help With Tire Size RyanF Titan Wheels, Tires & Brakes 0 01-31-2007 10:20 PM
Speedo adjustment for tire size. mopar Titan Wheels, Tires & Brakes 6 07-24-2006 01:12 PM
Tire size & speedo Rooster54 Titan Wheels, Tires & Brakes 1 11-18-2005 09:15 AM
Will this tire affect my speedo or anything else? new man Titan General Discussion 4 10-26-2005 01:07 PM
speedo correction??? squatch Titan Performance Modifications 1 01-02-2005 01:37 PM
