Help broken wheel stud!! Need help A.S.A.P.
 O.k., so I decided to save a few bucks and rotate my tires myself. Simple enough I have done it for years right. Well unfortunatley I broke a stud trying to get one of the back lugs off and another is going to break. The lugs weren't that tight but the studs are rusty and the last guys, who rotated my tires, (the dealership) didn't put anything on them. So my question for you expierenced Titan owners out there is are the studs the same front and back. I ask this because the parts houses I called to get new studs only have listings for the front. Being that it is four wheel disc brakes are the studs the same??? Also, if I take the brake caliper off does the rotor slide off then or is there a trick to get it off?? Thank you for any help. Hopefully I can get this fixed today.
'06 SE 4x4 Crew
Majestic Blue
O/R, R/F,T/P,U/P
Chrome Oval Nerfs(Tex. Titan style)
6" Pro Comp lift w/ traction bars,
Eagle Alloys Series 058 wheels,315/70/17 BFG AT KO
Billet grilles
Chrome tow mirror caps
Limo tint rear three windows
APS 787 Alarm w/ auto Start
Wet Okole seat covers
Pioneer TS-SW2541D 10's
PG MS 275 Amp. Made in the U.S.A.
MTX Re-Q
