Old 06-12-2007, 02:57 PM   #1 (permalink)
FFtitan's Avatar
Another offset question..
Im looking at some different wheels in 24x10 size. Now many manufacturers make a +18 and +35 offset for the same wheel yet recomend the 18 for the Titan. I would like something closer to the 5.5" Backspacing (+25 offset) so the wheel will tuck under the wheel well on the bed and the +35 accomplishes this. Would the +35 hit the spindle or anything else in the front? Is this why the are telling me to get the +18?
FFtitan is offline   Reply With Quote
Old 06-12-2007, 10:15 PM   #2 (permalink)
NorCal 4x4's Avatar
Re: Another offset question..
A 10" wide wheel with a +18mm offset has a 6.25" backspacing. So the rim will stick in towards the steering knuckle by 3/4" more than the OEM rims. Might work with a street tire but I wouldn't buy them on-line and end up paying for shipping them back.
With +35mm offset on a 10" width rim, you're looking at 7" b.s. ... I'd be surprised if the wheel would even go on, (even w/o a tire).
NorCal 4x4 is online now   Reply With Quote
Old 06-13-2007, 12:47 PM   #3 (permalink)
jguns2002's Avatar
I have a guy in my spreadsheet that is running 24x10's w/6.25BS & 18MM OS. Said no rubbing issues
jguns2002 is offline   Reply With Quote
Question about wheels and offset, I am dumb teamevolutionstitan Titan Wheels, Tires & Brakes 0 04-06-2007 12:39 PM
wheel offset question??? Baerman Titan Wheels, Tires & Brakes 2 11-08-2006 02:35 PM
Offset?? etalian2005 Titan Wheels, Tires & Brakes 3 09-27-2006 01:29 PM
prg on the way, so what rim offset! fearfact Titan Suspension 13 03-30-2006 06:56 AM
