Old 08-06-2007, 07:17 AM   #1 (permalink)
2005 OEM Tires - No Good - Need Replacement Tires Advice
I have had terrible luck with the OEM tires on my 2005 Nissan Titan Crewcab SE. I certainly don't want to use the same tires as a replacement. Can anyone recommend a good replacement?
I mainly drive in town and occassionally pull 2 different light weight trailors.
Thanks in advance
tonyjmay is offline   Reply With Quote
Old 08-06-2007, 07:26 AM   #2 (permalink)
54warrior's Avatar
Re: 2005 OEM Tires - No Good - Need Replacement Tires Advice
Check this thread:
Replacement tires for stock 18"s
2005 Nissan Titan CC SE 4x4
Old 08-06-2007, 02:07 PM   #3 (permalink)
Spencer@tirerack's Avatar
I love the AT REVOS!
Spencer@tirerack is offline   Reply With Quote
Old 08-06-2007, 03:06 PM   #4 (permalink)
dss90c's Avatar
I second the AT Revo's. The stock BFG's wore out for me way early. I put a set of Revo's on, and they have been great for over 10,000 miles.
2005 Smoke CC LE 4x4
Born on Date 3/05
Adopted 5/19/05
OR/BT Packages
Nav & DVD
Mods:
Truxedo Lo-Pro, Parrot CK3100 Bluetooth Hands-Free Speakerphone, Power Tailgate Lock, Zoomers Cannon Exhaust Tip, DEI 561T Remote Start, Line of Fire LED light bar, Backup Camera displayed on nav. screen
EBC Greenstuff pads & rotors, Aux. back-up lights, Wade In-Channel vent visors, keypad entry
dss90c is offline   Reply With Quote
Old 08-06-2007, 07:49 PM   #5 (permalink)
As you can tell, I am in the same boat as you. I am really leaning towards ordering the Revos on-line. Good luck...there are some alternatives out there for the stock 18's.
2005 2wd SE...Westin Oval tube steps, Rhino Lining, K&N FIPK II
warrenm is offline   Reply With Quote
Old 08-08-2007, 09:59 AM   #6 (permalink)
For highway use: Bridgestone H/L Alenzas (That's what I have on mine and the difference between these and your stock Goodyears are night and day.)
Off-road use: Revos are the most popular on this site!
TitanArmor is offline   Reply With Quote
Old 09-04-2007, 01:40 PM   #7 (permalink)
AMEN
These are awesome tires and less money than the Goodyears.
JD
jd1973 is offline   Reply With Quote
Old 09-04-2007, 02:39 PM   #8 (permalink)
Revos are way better. So much so that when I traded the '05 in on the '08, I specifically made them switch the Revos from the '05 to the '08. They only had 5000 miles on them, and I don't have the stomach for another set of the no traction Goodyears in the winter.
CentralMA_Titan is offline   Reply With Quote
Old 09-04-2007, 02:58 PM   #9 (permalink)
Nuke's Avatar
This weekend, I drove down a 2.5 mile gravel road. On the way back, about a mile from pavement, I got two simultaneous unrepairable flats. Stranded. The recovery was a long story, but let me just say that the Conti-nental Conti-tracToRs (the factory tires) conti-SUCK. Off highway at least. Don't buy them as replacements if you ever plan on going off pavement.
I wanted all-terrain tires and bought the Toyo Open Country ATs from Les Schwab. Pretty much the only 18-inch option within a 300-mile radius.
Nuke is offline   Reply With Quote
Old 09-04-2007, 07:02 PM   #10 (permalink)
gary748's Avatar
These are the tires I'm buying...The Alenzas have gotten really good reviews!
IRC VK56 PIT CREW CHEIF
2005 Silver SE 4X2 KC
Performance: Uprev Tuned, Injen CAI (Wrinkle Black Powder coated), '07 Intake Manifold, Nismo Exhaust,
TrueTrac, Mag-Hytec
Suspension: Stillen Rear Sway Bar, PRG Shackles
Wheels: 22" Foose DF-6(Black), Yokohama Prada-X tires
Exterior: Armada Front Air Dam, Catz 6k HIDS, DDM 6k fogs
Audio: JL Audio, Alpine
gary748 is offline   Reply With Quote
Old 02-09-2008, 08:10 PM   #11 (permalink)
BFG AT/KO's all the way
Scan999 is offline   Reply With Quote
Old 02-17-2008, 08:00 AM   #12 (permalink)
keiffers's Avatar
Send a message via MSN to keiffers Send a message via Yahoo to keiffers
I just put Destination LE's on mine to replace the stock GY SRAs I had....started going to crap at 25k but replaced at 31k....I've had them on for about 3 weeks now and I've noticed quite a difference already...no more spinning in wet weather so they seem to grip alot better than the SRAs ever did so no worries from me anymore....got them for $150 per but I already saw Firestone online quoting them at $140....they're the same tire at Bridgestone, just different badging...not Revos but still a good tire.
Keith
2004 Titan SE KC 4x2 - Smoke
"Chester"
SE Popular w/bench
SE Utility Bed Package
Drop-In K&N Air Filter
Delphi Roady 2 XM Radio
Sylvania SilverStars
Nissan wind/bug deflector
Nissan fog light kit
(good riddance Goodyear!!)
TomTom One 125 GPS
Born On Date - 03/19/04
Adopted On Date - 06/28/04
Maxwell Town North Nissan - Austin, TX
keiffers is offline   Reply With Quote
Old 02-21-2008, 11:27 AM   #13 (permalink)
It took me 2 months to decide on new tires, since the OEM Gdyrs suck. Traditionally, I'm a BFG A/T guy, but tried the Bridgestone Dueler A/T Revos, due to all the positive feedback on them. These are the best tires I've ever owned, by far! I changed from OEM size to 275/65R18 for thicker appearance and love em! These tires have an aggressive look and I did not have to sacrifice the smooth/quiet ride. They are a bit pricey, but well worth it. Also, rated very well in mud and snow. You will not be dissappointed. I will send pics if you want, long as I can figure out how to do so.
webbo is offline   Reply With Quote
Replacement tires for stock 18"s warrenm Titan Wheels, Tires & Brakes 19 08-08-2007 06:19 PM
replacement tires for stock 18inch Le racefan92307 Titan Wheels, Tires & Brakes 4 04-24-2007 07:42 AM
Replacement for OEM XE Tires BK19702 Titan Wheels, Tires & Brakes 9 01-31-2007 06:14 AM
Khumo road venture tires - good price if you need new tires. doctor steve Titan General Discussion 3 02-25-2006 12:45 PM
Replacement tires for my 18" wheels 54warrior Titan Wheels, Tires & Brakes 38 06-01-2005 02:39 PM
