Old 01-03-2008, 07:48 PM   #1 (permalink)
2008 Titan Wheel & Tire Fitment Question
Sorry in advance if this has been answered a million times, but after some searching I did not find anything...so here goes:
I just got a new 2008 Titan Pro-4x that comes with 275/70-18s which are 33.15" tall on a 8"x20" wheel with a 6x5.5 Bolt Pattern and what seems to be a 23mm Offset. I am going to junk the crap OEM Rugged Trails for either some Nitto Terra Grapplers or Cooper STTs, but I just got a set of Silverado SS 20" wheels which are 8.5"x20" with the same 6x5.5 Bolt Pattern and 22 mm offset.
So...the wheels are basically the same but a 1/2" wider and 1 mm different offset...
My question is, Should I either get the Hankook Ventus ST-RH06 275/55-20s which are 31.9" tall or the 305/50-20s which are 32" tall. I realize the 305s are closer to the OEM height, but will the 305s stick out past the fenders or will they fit nicely? I realize they won't rub b/c they are shorter, but I don't want that stupid look where the tires stick out past the fenders.
Thanks so much in advance.
bosssho is offline   Reply With Quote
Old 01-06-2008, 02:08 PM   #2 (permalink)
Re: 2008 Titan Wheel & Tire Fitment Question
I swear my 08 Pro-X4 has 17 inch rims are you sure about the 18's?
Just checked my tires, I guess I should not swear because my are 18's!!!!
cpd829 is offline   Reply With Quote
Old 01-06-2008, 03:18 PM   #3 (permalink)
I want to put 305/55-20 Nittos on my 2008 Titan 20s, but it's not clear whether they will clear everything. Clearances are tight on this truck.
Has anyone done this yet?
cmclovis is offline   Reply With Quote
Old 01-07-2008, 06:20 PM   #4 (permalink)
Can anyone who knows anything help us? In other forums I'm in a question like this would be answered 10 times in a 1/2 hr so it would be appreciated by us if the experts would please chime in, thanks.
Old 01-08-2008, 09:08 AM   #5 (permalink)
TravisDTD's Avatar
Here is some help fellas:
What the SS wheels you have choosen a safe size would be a 285.55.20. they should fit without problems. the 305.55.20's might clear just fine but I would suggest test fitting. The only problem area you might have and I stress "might" would be at full lock when turning right and left. Terra Grapplers are a great tire and would be an excelent choice. I would also suggest BFG AT KO's or Cooper Zeon LTZ's. in either size. Here is a helpfull link that shows all the upgraded sizes that are relatively easy to put on your 2008 Titan. (relatively because offset is always a contributing factor
http://www.discounttiredirect.com/di...SAN&vid=011810
*note BFG has a $50 rebate I see.
As for anyone else that want to fit a 305.55.20 aim for a 20x9 or 20x9.5 with an offset in the range of 18mm *** Always test fit when upsizing.
TravisDTD is offline   Reply With Quote
Old 01-08-2008, 09:27 AM   #6 (permalink)
Pops's Avatar
Go with 305/55/20s!!! You'll be glad you did, 92TripleBlack has been running them w/o any fitment issues that I have seen. I'm running 325/60-18s which pan out to the same size but a tiny bit wider and I love them. Most 33's will fit on stock height with stock offset. 35's will require a leveling kit.
Here's mine with the PRG Mini-Lift although the lift is not required.
2005 Armada LE 4x4 - 2* Timing Advance - AirBox Mod - PRG Mini-Lift - Nitto TerraGrapplers 325/60-18
_____________
. Check out my Gallery! .
Old 01-08-2008, 10:11 AM   #7 (permalink)
TravisDTD's Avatar
Good lookin pops, I've been wanting to see the 35"s with a leveling kit though. Have you seen any pics? There were a few threads posted asking for them like this one:
post pics: 35's w/ level kit
Old 01-08-2008, 10:48 AM   #8 (permalink)
Pops's Avatar
I haven't seen any either, I've been really curious about them as well but I didn't want to fork out an extra $100/tire just to see what they look like. $1030.00 was pricey enough for me the way it is. I'll look around as soon as maintenance is done on the other sites.
_____________
Old 01-08-2008, 11:02 AM   #9 (permalink)
Pops's Avatar
Found one with a 4" Fabtech. Still looking for one w/ the 2" Leveling Kit. This is RedTitanLE's from CT before she traded it in for a Tundra.
http://mightytitans.boardnation.com/...16531#msg16531
Here's her specs:
2WD King Cab:
4 inch CST spindles
Donohoe Racing coilovers
Bilstein rear shocks
Deaver mini pack
2 inch tapered Fabtech blocks
Nitto Mud Grapplers 35x12.5x18
Moto Metal 951s 18x9 4.5 bs
_____________
Old 01-08-2008, 11:45 AM   #10 (permalink)
TravisDTD's Avatar
Looks good, Let me know if you find anything.
Old 01-08-2008, 12:33 PM   #11 (permalink)
Pops's Avatar
Found this one. He's running 35x12.5-18 w/ the PRG 4WD Leveling Kit and said that the Pinch-Weld Mod is needed to completely clear.
http://www.club titan.org/forums/showthread.php?p=502489
http://i33.photobucket.com/albums/d9...n/DSCN1174.jpg
http://i33.photobucket.com/albums/d9...n/DSCN1178.jpg
http://i33.photobucket.com/albums/d9...n/DSCN1182.jpg
http://i33.photobucket.com/albums/d9...n/DSCN1186.jpg
http://i33.photobucket.com/albums/d9...n/DSCN1175.jpg
_____________
Old 01-08-2008, 01:16 PM   #12 (permalink)
TravisDTD's Avatar
Nice work Pops! Awesome find. I know a few people on here will be happy to see, do you know if the guy is a member of TT?
Old 01-08-2008, 01:36 PM   #13 (permalink)
Pops's Avatar
I can't find him over here. Do you want me to send him a PM and ask him if he could signup and provide more info here??
_____________
Old 01-08-2008, 03:21 PM   #14 (permalink)
TravisDTD's Avatar
Shoot yeah, send him the link I posted.
Old 01-08-2008, 03:39 PM   #15 (permalink)
Pops's Avatar
Done deal, PM sent.
wheel and tire fitment ? troutman Titan Wheels, Tires & Brakes 1 05-03-2007 02:08 AM
wheel and tire fitment troutman Titan Wheels, Tires & Brakes 3 04-05-2007 10:13 AM
Another wheel fitment question wssboard18 Titan Wheels, Tires & Brakes 12 03-05-2007 04:38 PM
Wheel Fitment Question sdcantrell Titan Wheels, Tires & Brakes 7 12-28-2006 09:13 PM
Another wheel fitment question jbennett Titan Wheels, Tires & Brakes 6 09-23-2006 09:50 AM
