Old 02-10-2008, 09:45 PM   #1 (permalink)
tholmes's Avatar
Will E rated tires effect Mileage?
Need some new tires.. again. OEM GY's lasted 43K first go round, and about 35K second time round. I am looking at two tires, the GY Silent Armor's seen here: http://www.kauffmantire.com/proddeta...Diameter:%2018
Or these beauties from Cooper: http://ssl.delti.com/cgi-bin/reifenb...140016&dsco=35
MAin difference is the GY's are a slightly larger size and weigh 12lbs more per tire. I talked to a local tire guy and he said most people who put E rated tires on pickups come back complaining of severe loss of mpg (2mpg). I drive 30K plus mile per year and I would be concerned about 2mpg loss. Any input from those that havce gobe to the heavier E rated tires? Are you seeing a bad loss in mpg? I don't care about the ride. Any input is much appreciated.
If it's a penny for your thoughts, and you give me your two cents, what happens to the other penny? Taxes, the Democrats tax everything!
Robert Holmes
2005 Titan LE Crew Cab 4x4 ***Gone, but not forgotten. Take your trailer hitch off when not towing, or else an impact could buckle your frame and warp your bed, causing the insurance company to total your truck ***
tholmes is offline   Reply With Quote
Old 02-11-2008, 09:13 AM   #2 (permalink)
tholmes's Avatar
Re: Will E rated tires effect Mileage?
bump...anyone?
Robert Holmes
Old 02-11-2008, 12:09 PM   #3 (permalink)
NorCal 4x4's Avatar
On my stock BFG All-Season Rugged Trail 44 lbs. 33" P285/70/17 = 14 mpg
Then on my BFG AT KO D-rated 58 lbs. 32.8" LT285/70/17 = 13 mpg
For my 320 miles per week they cost me an extra 1.76 gallons. At the current $3.08/gallon that would cost me an extra $5.40 a week, over stock.
Currently running the Toyo M/T E-rated 73 lbs. 33.5" LT295/70/17 = 12.0 mpg
And the M/Ts, with my 320 miles per week cost me an extra 3.5 gallons. At the current $3.08/gallon that would cost me an extra $10.80 a week, over stock.
NorCal 4x4 is online now   Reply With Quote
Old 02-11-2008, 01:53 PM   #4 (permalink)
tholmes's Avatar
Perfect... Thanks for the info!
Robert Holmes
Old 02-11-2008, 04:03 PM   #5 (permalink)
TitanBlue's Avatar
I just bought the DELTA Sierradial whichs weighs in at 40#, has a 2773 # Paylaod per tire and is designed with a smooth, quiet, highway tread. It does not have high traction for cornering like a sports car, but for good mileage and qualities stated, it seems to really deliver. I tend to get 14-15 local (12 miles to work) and 19+, even 20! Highway. I carry excess weight with tool boxes in rear and am a BT CC.
DYNO: 308 RWHP & 380 RWTQ
~CRANK: 360 HP & 450 TQ
Born June 12, 2006
Adopted June 27, 2006
Old 02-12-2008, 12:59 PM   #6 (permalink)
Steamguy's Avatar
I've got a data point for you: I've got the Continentals, and have about 45,000 miles on them. Some stuff I noticed:
-The handling on the truck is MUCH tighter. Those stiff tires REALLY tune up the driving experience. You're going to notice it IMMEDIATELY when you drive away from the tire store.
-The tires are a little sensitive to alignment. I need to get mine done, more from the fields and rough roads I drive on. The gas mileage has been down about 1 MPG on average. I used to get 14.8 to 15 MPG average on those crappy Goodyears, but on the Continentals it was about the same for quite a while. I'm now getting 14.2 best, 13.8 worst. Winter blend fuel, that goes out the window to the tune of 12 MPG.
Don't forget to have the alignment checked. You can throw a lot of money away in lost gas mileage through misalignment.
Old 02-12-2008, 05:05 PM   #7 (permalink)
Shane06fl's Avatar
I put on the Michelin cross terrains at 35k miles. They should make it to 80k miles but since they have a 60K mile tread wear I won't pay full price again. At 45k miles of use I will pay right at $300 for new tires. If they do last for 60,000 miles I will be happy.
I gained in MPG over the stock GY tires, sorry I don't remember the exact figure. Tires are stiffer and make for tad rougher ride compared to the GY tires.
IMO tread wear warranty and free tire replacement road hazard is worth the extra $$$.
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC SE
Big Tow
4x4
Silver
Bed shell effect on gas mileage dennisuello Titan General Discussion 6 12-06-2007 12:49 PM
Thoughts on "E" rated tires? Urban_Cowboy Titan Wheels, Tires & Brakes 9 12-14-2006 09:38 AM
E rated vs D rated tires? BroncoAZ Titan Wheels, Tires & Brakes 4 10-27-2006 12:09 PM
Effect of right foot on gas mileage KTMNealio Titan General Discussion 19 06-08-2005 12:32 AM
How much mileage out of the stock tires? TxTitan Titan General Discussion 26 12-14-2004 04:25 PM
