Old 02-13-2008, 05:45 PM   #1 (permalink)
nicojames's Avatar
help with offset one more time
20X9.5 6-139.7HC 15 offset how will i be sitting??? sticking out or sitting right?
nicojames is offline   Reply With Quote
Old 02-13-2008, 06:12 PM   #2 (permalink)
MFresh's Avatar
Re: help with offset one more time
Is that +15 offset. If it is you're lookin at 1.2" stickin out more than stock. That's only the wheels. Could stick out more depending on how wide a tire you go.
MFresh is offline   Reply With Quote
Old 02-13-2008, 06:22 PM   #3 (permalink)
nicojames's Avatar
+15 w/ 305-50-20 tires
Old 02-13-2008, 06:27 PM   #4 (permalink)
Kronos1965's Avatar
+12mm is stock I believe...
Kronos1965 is offline   Reply With Quote
Old 02-14-2008, 07:10 AM   #5 (permalink)
TheBoondockTitan's Avatar
It would probably stick out roughly a 1/4 of an inch, or a little more.
2007 Nissan Titan Galaxy black. Going lower for better cornering, because it's funny when I keep up with people in twisties. Plus a black truck is fun at night. They can't see it.
18x9 Helo Maxx 6 Black-285/60/18 Sumitomo HTR Sport
Beretta 92FS anti-theft system
TheBoondockTitan is offline   Reply With Quote
Old 02-14-2008, 06:33 PM   #6 (permalink)
NorCal 4x4's Avatar
With +15mm offset and a 9.5" wide wheel the backspacing is roughly 5.84", (0.34" more than a stock SE or LE rim, which are 8" wide with +25mm offset).
So 9.5" - 8" - 0.34" = 1.16" or so more than stock. Looks like MFresh got it right.
Old 02-15-2008, 05:15 AM   #7 (permalink)
nicojames's Avatar
is 1" a lot??? will it be funny looking or barely noticalbe...
Old 02-15-2008, 09:34 AM   #8 (permalink)
TravisDTD's Avatar
20x9.5 with +15 would be just about flush with the fenders. You 305 migh be out 1/4"-1/3".
TravisDTD is offline   Reply With Quote
Old 02-15-2008, 11:18 AM   #9 (permalink)
MFresh's Avatar
Depends on your setup. Lowered probably look funny. Stock height might not be too bad. Leveling kit might look perfect!
Just my own opinion lowered should be flush or tucked in. The higher you go gotta have a wider stance!
Old 02-15-2008, 11:43 AM   #10 (permalink)
nicojames's Avatar
thanx for the help guys...i plan on running 305-50-20 tires at stock height for now, and a leveling kit in the future
Old 02-18-2008, 07:08 PM   #11 (permalink)
looking at a wheel that comes 20x10 with a -24 ET...
about how much would that stick out? Want to fit 35" Toyo M/T
thx
'07 Black SE 2WD "Poser"
Skumbag is offline   Reply With Quote
Old 02-18-2008, 07:26 PM   #12 (permalink)
NorCal 4x4's Avatar
thx
What mods have you got?
What's ET?
Anyhow, if that it is a -24mm offset with 10" rims the backspacing is about 4.5", which even for a stock width rim would stick out almost an inch more. Since the stock SE and LE rims are 8" wide and that one is 10", you'd be sticking out about 3" more than stock!
I know a guy with 9" Moto Metal 951s with 4.5" backspacing that had to do the pinch weld mod with a PC1 6" lift.
help with offset.... nicojames Titan Wheels, Tires & Brakes 6 02-01-2008 05:19 PM
offset help!!! toothlesswonder Titan Wheels, Tires & Brakes 5 12-19-2007 05:08 PM
Offset?? etalian2005 Titan Wheels, Tires & Brakes 3 09-27-2006 01:29 PM
Long time reader, first time writer PTitan Titan General Discussion 3 08-03-2005 07:30 PM
Long time reader first time poster... Huey130 Titan General Discussion 9 10-29-2004 01:13 PM
