Old 02-15-2008, 11:23 AM   #1 (permalink)
will chevy 6 lugs fit on a titan?
probably retarded question but owell. i found a set of 20 in rockstars w/chevy 6 lug pattern on 35's for a really good price. would it fit on my titan offrd with the prg fornt and deaver 2.5 rear springs?
fearfact is offline   Reply With Quote
Old 02-15-2008, 12:10 PM   #2 (permalink)
MFresh's Avatar
Re: will chevy 6 lugs fit on a titan?
As far as the lug pattern should be no problem. I think it's the same bolt pattern just different studs. My cousin has my OR wheels on his 06 Chevy Tahoe no problems.
You say you have the PRG's (which ones? mini,leveling, PRG 4" w/CST). You probably can fit the tires with the 4" CST, but would have problems with anything less. Another problem is what is the BS/Offset of the wheels? Too much offset you'll rub the spindle. Negative offsets, depends on how much you wanna cut!
MFresh is offline   Reply With Quote
Old 02-15-2008, 01:08 PM   #3 (permalink)
ive got the 2.5 leveling kit, so i kno i can runa 35 with my stock rims and a little trim possibly... i just dont know any details on these tire/rim.. really cheap ad on craiglist
Old 02-15-2008, 03:29 PM   #4 (permalink)
TravisDTD's Avatar
yeah they should fit if they are off a 1500 chevy truck, they are the same boltpattern. As for how much trimming you would have to do????? not sure.
6-139.7 is Chevy 1500 Trucks, also Tahoe
6-139.7 is Titan
You might need to buy the correct Lugs, the lugs from your stock wheels might not seat correctly.
TravisDTD is offline   Reply With Quote
Old 02-18-2008, 05:39 PM   #5 (permalink)
wasn't a problem for me. i swapped with a 93 chevy 1500 4x4 with my 04 titan 4x4. just had to get the correct size lug nuts.
boeavers is offline   Reply With Quote
Old 02-19-2008, 08:37 AM   #6 (permalink)
rcantu's Avatar
i saw that ad. it's a pretty decent deal if they're in the condition he claims. do a test fit if you're concerned. it's just the front you need to check out.
pics of the Titan
Old 02-19-2008, 09:46 AM   #7 (permalink)
juscuzram's Avatar
Send a message via AIM to juscuzram
Buddy of mine has some Foose 23's that were originally on a Chevy. Only problem he had was a slight rub on the brake caliper. There's a little "tab" that sticks out of the front of the caliper that he had to grind down very slightly. Now they fit and look great! He did buy new lugs though.
Jus Cuz Designs...Respect This!
MYSPACE
2006 Nissan Titan SE KC
Big Tow
NCD 2.5" Leveling kit
Toyo Open Country A/T
Magnaflow Duals
Hurst T-Handle
T-Rex Billet Grille Inserts
Pioneer AVH-P4100DVD Head
Memphis MClass 10s
Memphis SC 1.500 Amp
Memphis MClass 6x9s
Memphis Tweets
Autotek SS490.4 Amp
juscuzram is offline   Reply With Quote
XE Lugs work on SE/LE Rims? 4DRSS Titan Wheels, Tires & Brakes 3 10-11-2006 08:08 PM
Tuner Lugs, where to get them? CopperheadTitan Titan Parts & Accessories 2 06-25-2006 09:12 PM
5 xe wheels tires w/ lugs and centers got_titan Buy/Sell 0 02-18-2006 10:36 PM
Videos of Titan Vs F250, Z, Chevy: Stock Titan Quarter Mile Runs hail108 War Stories 18 06-13-2005 04:55 PM
