Old 02-25-2008, 11:30 AM   #1 (permalink)
Brake noise when backing-up
Greetings Titan Bro's I Need help: I have a 2004 Titan and when I back-up and apply the brakes the truck makes a loud grown. Any Idea's as to what it could be and how to fix it? Thanks..... Jimbo
jimbo is offline   Reply With Quote
Old 02-25-2008, 11:44 AM   #2 (permalink)
Re: Brake noise when backing-up
Sounds like your pads have had it!!
Check your rotors for wear!
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
AKA: The Hijack King™
AKA: The Troll Hunter™
bbomar is online now   Reply With Quote
Old 02-25-2008, 12:20 PM   #3 (permalink)
I checked the pads and they are good.
Old 02-25-2008, 12:33 PM   #4 (permalink)
I would replace the pads, and have the rotors turned.Should help your problem.
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
Old 02-25-2008, 12:40 PM   #5 (permalink)
Kronos1965's Avatar
How many miles?
Could also be glazing and getting new pads may also require getting your rotors cleaned.
Kronos1965 is offline   Reply With Quote
Old 02-26-2008, 07:23 AM   #6 (permalink)
GoFast33's Avatar
Yeah, this seems to be a common problem! I hear it at very low speeds going forward and reverse. I had this problem with my '07 and now with my '08. On the '07, they replace the pads and turned the rotors which resolved the issue. I am going to have them do it again on the new truck when I take it in for the first oil change.
2008 Pro-4X Crew Cab Long Bed
Pro Comp 6", SAW front (0.75" preload), SAW rear, 18x9 XD Rockstar, 35x12.5x18 BFG KM2
GoFast33 is offline   Reply With Quote
Old 02-26-2008, 07:46 AM   #7 (permalink)
I've had the same issue with my '08. Took it in last week to the dealer and the service advisor told me this was a common issue they were seeing. The service advisor felt it was caused by a combination of humidity and poor quality of materials. Needless to say, the brakes are still noisy. My wife's Altima has been doing the same thing for months but not just in reverse...they squeak every time the brakes are applied. I've had the dealer check them twice and they can't find issue with them.
claxton is offline   Reply With Quote
Old 03-13-2008, 01:58 PM   #8 (permalink)
Found out the problem. It was my parking brake and when it got worse it hung up and would not fully release. The dealer fixed at no cost and the pads were 90% and 80% good to go . No more noise hope all of you see this post. Thanks....Jimbo
Old 03-13-2008, 06:48 PM   #9 (permalink)
Thanks...very helpful. I'm actually going in the morning to get the A/C recall taken care of so I'll bring this up again.
New noise...think it's a brake...help? Nutdotnet Titan Wheels, Tires & Brakes 4 12-12-2007 12:42 PM
Front brake noise Intimidator Titan General Discussion 1 11-28-2006 01:38 PM
Brake Squeal when backing up? Taskmaxter Titan General Discussion 4 11-30-2005 02:34 PM
Brake noise when backing up chue Titan General Discussion 1 03-19-2005 11:32 AM
Brake Noise TennTitan Titan Problems & Dealer Service 7 02-27-2004 10:20 PM
