Wheels fit no contact and no grinding needed! a after market wheel with stock specs! now off to order 37x12.50r17 Hankook mt's
Jim at newsouthwheel was great to deal with, great prices and they ship. http://www.newsouthwheel.com/index.htm
Congratulations! You committed to buy the following item:
4-LT 37 12.50 R 17 10 PLY HANKOOK DYNAPRO RT03 MUD TIRE
on second thought, the ultra wheels are ugly and look completely wrong on the titan. hopefully you can cancel the order and get your money back.
uh.......thanks ? have you seen them on Titan ? I bought these because they are different and most important they are within the stock parameters. the tires WILL easily tuck under the pulled bedsides AND will be better for wheel bearing wear. FUNCTION FIRST!
yeah, a new pro4x had them on and it looked all wrong on the truck.
LMAO!!!! just messin Bech!!! they look like they'll be badaass!
Nice ultras.... I ordered the black ones..17x10 and -25 offset and 3 weeks of back order
I also was looking to get the Jesse James widows.. but they are $325 a piece! and the ultras are only $108 a Piece!
yeah gonna look BADAASS!!! i told bech to get the black ones... the black ones are gonna look kickAass carnal!!! kinda wide though but yer tires will like it wide...
I think those are too wide and will cause problems. 2" wider thank stock -25 off set will put the inner wheel lip at the stock backspacing so you will have 2" sticking out. so when you turn the outside corner of the tire will most likely rub. NO! that wheel is a total of 11" wide divided 2 = 5.5" with 0 offset that wheel will have you sticking out 3" with a -25 offset. 4.5" backspacing. I think you should change your order. to this or this.
part# 175-7884B 17x8 offset:+25 lug pattern: 6on5.5 bore: 78mm hub centric
part# 175-7883B 17x8 offset:+10 lug pattern: 6on5.5 bore:108mm lug centric
I think they got almost the same specs as my procomps.... but I'll see once they get to the shop... or even better I'll see what we have in stock with the same specs as the ultras an thest fit them.
rub shmub... that's what a sawzalls for carnal!!!!
lmfao... I had rubbing issues w/17x9 -12 offset... you'll have to cut back into the cab to clear those with wide tires how much lift and how tall/wide tires?
just found the info on my procomps 1079-7938*17x9 6x5.5 -6mm 4.75" and no rubbing issues with just the spindles......... I guess I'm going to have to get a differente off set.......
The Pro-comp's you have now stick out 1-3/4" more than stock and the 10" wide -25 offset would have stuck out 1-1/4" more than that. Having the wheel specs that far off from stock is not good for the wheel bearing's either. after a while you will hear click click click click............time for new wheel bearing's.
