Originally Posted by jwags034
I found the wheels I want but the offset is -12 and dude advised me that they would stick out about 2inchs from the wheel well. Does anyone have pics of -12 offset wheels? Would this offset look like **** on a leveled non-lifted truck.
-12 offset hmmmm ... On an 8" width wheel it would have a 4" backspacing. Stock SE and LE '04-'07 were 8" with a 5.5" backspacing, so they stick out 1.5" more than stock.
8.5" w/-12mm offset have a 4.25" backspacing so would stick out 1.75" more.
9" with -12 offset is 4.5" b.s. and would stick out 2" more.
Depending on the tire diameter, you might need
Kartman's Pinch-Weld-Mod. I read about a member needing this with 17x9" Moto Metal 951 with 4.5" b.s. and some Nitto Terra Grappler LT295/70/17 (33.3" diameter).
