Old 04-18-2008, 11:57 PM   #1 (permalink)
Low tire light
I jsut got new wheels and tires. And I have a few questions. Ist I went from 17" to 18" will this affect my truck 2nd the low tire pressure light will not go off. Are the sensors in the tire and if so can they be removed and reused. If not how do iget the light to stay off. It is a 06. thanks for any help.
keener205 is offline   Reply With Quote
Old 04-19-2008, 05:53 AM   #2 (permalink)
Quartz's Avatar
Re: Low tire light
Are you going from street tires to off road tires? What about the rim? Are the new tires wider, taller, heavier?
Going from a 17 to 18 will make very little difference if the overall diameter and type of tire is the same. It's the combination of the type, width, diameter, and weight of the tire and the weight and offset of the rim that will make the overall difference.
The sensors can be moved from the stock rim to most other rims but it should have been done when the tires were mounted. Until they are properly installed, the tire pressure warning light will not go out,
Old 04-19-2008, 07:24 PM   #3 (permalink)
Re: Low tire light
Thanks for the information. I will have to get new sensors or get my old ones back
Low Tire Pressure light CStewTAMU Titan General Discussion 8 10-30-2007 11:36 AM
low tire pressure light? white_titan05 Titan General Discussion 4 03-19-2007 09:18 AM
Low Tire Pressure Light Professor Titan General Discussion 9 11-11-2005 06:19 PM
Tire pressure light!?!?! Titan1080 Titan General Discussion 19 09-23-2005 03:06 PM
low tire light rawze Titan General Discussion 15 11-16-2004 06:43 PM
