Re: Low tire light
Are you going from street tires to off road tires? What about the rim? Are the new tires wider, taller, heavier?
Going from a 17 to 18 will make very little difference if the overall diameter and type of tire is the same. It's the combination of the type, width, diameter, and weight of the tire and the weight and offset of the rim that will make the overall difference.
The sensors can be moved from the stock rim to most other rims but it should have been done when the tires were mounted. Until they are properly installed, the tire pressure warning light will not go out,
O6 4X2 Granite SE CC, Big Tow & SE Popular Pkg, Nissan bed extender and bug deflector, Tekonsha Prodigy, Sylvania Silverstars, Zoomers Canon Exhaust Tip, Armada front spoiler, Parrot CK3100 Bluetooth, NCD 2.5" leveling kit, Go Rhino Dominator II nerf bars, AEM Brute Force, Roadmaster Active Suspension
