Old 04-18-2008, 06:00 AM   #1 (permalink)
Peytons_Titan08's Avatar
Gas Milage/wear/ride difference in these two tires?
Looking to get one of the following:
33x12.5x18 Toyo Open Country M/T
325/65/18 Open Country A/T
Is the gas milage that different? What about ride and wear? Thanks
2008 Titan XE KC
Exterior:
DeBadged
6000k HID
Performance:
K&N CAI
Audio:
Alpine IDA-X001
JL 300/4 Powering - 4 Polk Audio 6.5"
JL 500/1 Powering - 1 JL 10W3v3
Suspension/Wheels:
Total Chaos Upper Control Arms
4" CST Spindle Lift w/4" Rear Block
Sway-A-Way Coilover's (1" preload)
Sway-A-Way 2.25" Rear's
18" Black/Red Ballistic Offroad Jesters (waiting on delivery) wrapped in 325/65 Terra Grapplers.
"LIFE IS GOOD"
Peytons_Titan08 is online now   Reply With Quote
Old 04-18-2008, 01:37 PM   #2 (permalink)
Megw3788's Avatar
Send a message via AIM to Megw3788
Re: Gas Milage/wear/ride difference in these two tires?
Not sure about the gas mileage difference, but you should get around 40k miles out of both sets of tires. And as for the ride difference, it' not bad at all, I'd say the difference between the two would be equivelent to the difference between going from stock tires to ATs at the most.
Megw3788 is offline   Reply With Quote
Old 04-18-2008, 02:18 PM   #3 (permalink)
There will be a decent difference in gas mileage since one is a 33 and the other a 35, and the 325 is 13" wide as well.
Noseeum is offline   Reply With Quote
Old 04-19-2008, 11:47 AM   #4 (permalink)
NorCal 4x4's Avatar
Toyo M/T 33x12.5R18LT 33.0" diameter 75 lbs.
Toyo AT LT325/65R18 121R D/8 34.5" dia. 75 lbs.
As far as gas mileage, since they are the same weight, that's a push unless you went with wider/heavier rims for the 325s.The larger diameter of the 325 will raise your overall gearing. In theory this might actually improve your gas mileage, but with a Titan, it can also lead to torque convert not locking when it should, and later shifting, which would use more gas, and the larger diameter gives you less apparent power.
For an 18" rim and a 33" Toyo AT, I'd get the LT285/65R18 125S E/10, only 57 lbs, and 32.5" diameter, or a LT275/70R18 125S E/10, at 55 lbs, and 33.1" diameter.
For the Toyo M/T a LT275/70R18 125P E/10 at 66 lbs. and 33.6" would be better, although still a little heavy.
I have Toyo M/Ts in a 73 lbs. 33.5" diameter and they are definitely not as smooth or as quick at acceleration as my aftermarket, 58 lbs. 32.8" dia. BFG AT KOs were. Plus I lost a little bit over 1 mpg compared to the KOs, (2 mpg compared to stock 44lbs. 33s).
NorCal 4x4 is online now   Reply With Quote
Old 04-19-2008, 09:46 PM   #5 (permalink)
thanks man, that info helps me tons. your the man.
2008 Titan XE KC
Exterior:
DeBadged
6000k HID
Performance:
K&N CAI
Audio:
Alpine IDA-X001
Suspension/Wheels:
"LIFE IS GOOD"
any picture of 6" lift or 2" leveling kit with 35" tires to compare high difference? d0va Titan Suspension 29 02-18-2008 09:02 AM
Tread Wear on stock tires WTF??? (pics attached) Mike422 Titan Wheels, Tires & Brakes 33 10-04-2007 08:43 PM
Whats the difference in the ride SKEET Titan General Discussion 2 03-29-2006 05:34 AM
Does anyone wear a bra? Bayou Titan Titan General Discussion 16 07-02-2005 06:04 PM
Ride difference between Off Road Package and standard shocks solecky Titan General Discussion 9 01-31-2005 04:48 PM
