Go Back   Nissan Titan Forums > Titan Technical Discussion Area > Titan Wheels, Tires & Brakes
User Name
Password
Help - calipers rubbing new wheels - being discussed at Nissan Titan Forums in the Titan Wheels, Tires & Brakes section.
Old 05-03-2008, 03:18 PM   #1
deauxx
deauxx's Avatar
Send a message via MSN to deauxx
Angry Help - calipers rubbing new wheels
I have an '08 Pro-4SX and I am having a Pro Comp Stage 1 lift installed with 20" Pro-Comp 6001 series wheels. I got a call from 4 Wheel Parts (where the work is being done) today and they told me that these massive 20" wheels won't work with my existing calipers. That is hard to believe considering the stockers were 18" and they fit fine. BUt it is what it is I guess. The tech said there is not enough material on the stock calipers to "clearance" them to fit. So I guess I have two choices, pick a different wheel or change calipers. I need a cheap solution here - I am already pretty much tapped out for the wheels, tires, and lift kit + install. Any suggestions / thoughts / ideas?
Gig ' Em Aggies!
deauxx is offline   Reply With Quote
Old 05-03-2008, 03:53 PM   #2
MFresh
MFresh's Avatar
Re: Help - calipers rubbing new wheels
There's two areas where the caliper will rub on the wheels. The outer diameter which is alleviated by getting a larger diameter wheel.
And the other is the caliper overhang. The Titans caliper extends past the mounting surface of the hub, so if the face of the wheel is flat rather than taper away from the hub, the wheel will rub. All depends on the design of the wheel. If your dead set on those wheels, spacers will work.
I believe most KMC XD wheels will clear the caliper. Take a look at Moto Metal 951's I believe they'll fit.
MFresh is offline   Reply With Quote
Old 05-03-2008, 07:17 PM   #3
WhiteTitanSe
WhiteTitanSe's Avatar
Or depending on what pro comp wheels you have trade me Ill drive down there .....I mean to help you out in your time of need! lol
2004 SE, BT, NAV, Intake, Flowmaster,Timing Adv., 10"'s of lift, 35" Toyo M/Ts, 20 x 10 Helo Maxx Blacked Out...
WhiteTitanSe is offline   Reply With Quote
User Name
Password
New wheels for Titans with custom brake calipers wont work? TitanCake Titan General Discussion 8 08-27-2007 08:29 AM
Calipers Advocate07 Titan General Discussion 3 02-19-2007 06:02 PM
Can you fit 35" tires on the 18" stock wheels with no rubbing? archer75 Titan Wheels, Tires & Brakes 7 02-10-2007 05:54 PM
Painted Calipers Blue TCW Titan Pictures & Media Post 9 11-01-2006 12:21 PM
WTB: calipers, hubs lifeinthesouth Buy/Sell 3 09-18-2006 03:03 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
