05-14-2008, 02:32 PM
#1 (permalink )
Flat Tire!!!
So long story short i got a flat on my way home from work yesterday...
Anyways, the little yellow lite came on when it started going flat warning me that something was a loof. its a exclamation mark with a circle around it.
Now the tire is fixed and everything is good, but the darn lite is still on...how do I get it to turn off?
05-14-2008, 02:37 PM
#2 (permalink )
Re: Flat Tire!!!
Check the pressure in all the tires, make sure they are within 3lbs of each other.
ZlacherWhore™
Why is there never enough time to do it right the first time,
But always enough time to do it again?
05-14-2008, 03:50 PM
#3 (permalink )
Re: Flat Tire!!!
I always have a tire plug kit in my truck.
[IMG]
[/IMG]
07' Osceola Swamp Runner
05-14-2008, 03:58 PM
#4 (permalink )
Re: Flat Tire!!!
If all is well, you have to drive a certain amount of mileage before it turns off (I think 15miles?).
05-14-2008, 08:51 PM
#5 (permalink )
Re: Flat Tire!!!
The TPMS works using static electricity, so you have to drive a bit for the new pressure to register. Keep in mind that if you simply put the spare on it will stay one. You might also want to check your other tires. I believe the light turns on when the psi drops to 25.
2004 Nissan Titan Galaxy Black King Cab SE
Street Scene Chrome Speed Grills, HID Headlights, Viper Alarm with Remote Start, Pioneer Navigation w/rear view camera, Bilstein 5100's Shocks on Front and Icons on the rear
05-14-2008, 10:04 PM
#6 (permalink )
Re: Flat Tire!!!
I just got the spare on it for now, the other tire is ruined. the belts separated insdie after a puncture from the side wall.
05-14-2008, 10:23 PM
#7 (permalink )
Re: Flat Tire!!!
Probably no sensor in the spare. When you get the original rim with the sensor back on there the light should go out.
08 LE 4x4 Majestic Blue w/Tow. SAW C/O's (2.5" preload). PRG UCA's. PWM. Swaybar removed. SAW Piggybacks. Deaver C10 leaf pack (largest leaf removed). PRG Shackles (set at -1"). PRG OR Traction Bars. American Racing Motto MT100 20x8.5 chrome wheels. 35x12.50 Toyo M/T's. AEM Brute Force Intake. Nismo Exhaust. 2 Degree Advance. AMP Powersteps. Hella 500 driving lights. ScanGuageII. Debadged.
05-15-2008, 05:04 AM
#8 (permalink )
Re: Flat Tire!!!
Originally Posted by stanzaboi
The TPMS works using static electricity...
Uhhh...No.
It uses RF, sorta like RFID and your keyless entry fob.
Improvements:
K&N Drop in, Magnaflow muffler, Step Tubes, Reese Hitch, Husky Liners, Nitto Terra Grapplers 285/70/17
Air Box mod ,
Improved Fog Light Mod ,
dba 4000 series rotors, Akebono ProACT pads , Extang RT Tonneau, RadFlo Remote Res Rears, OEM Hood Deflector
Wish List: Air Horn, RadFlo 2.0 Coilovers, AEM Brute Force CAI, TruTrac, Bass boat...
Donations graciously accepted.
Display Modes
Rate This Thread
Linear Mode
Thread
Thread Starter
Forum
Replies
Last Post
Flat Tire.
LoudPipes
10
10-03-2007 01:12 PM
Flat Tire
Blizzard
7
07-31-2007 10:48 AM
Flat tire indicator lit up last night
rrumaner
Titan General Discussion
15
11-19-2005 11:53 AM
Flat Tire
Justintoxicated
10
08-19-2005 08:03 PM
Flat Tire
bbqhog
Titan Problems & Dealer Service
9
06-04-2004 11:11 PM
AutoForums.com
Truck
European
Import
Domestic
Manufacturer
