Old 05-14-2008, 09:03 PM   #1 (permalink)
Ok, so I think I understand backspacing...
.. but maybe not.
I know factory backspacing is 5.5" correct? So what will happen if I buy a set of rims with 4.5" backspacing? Will the rims stick out past the edge of the truck an inch? Will I be able to clear these wheels with my 315/70/17 tires?
I found a set that I like on eBay. I originally wanted the Mazzi Hulks but I decided I like the simplicity of the Eagle 058's instead. Plus, they're chrome which will tie in with my current theme of chrome handles/mirrors/steps.
I just don't want to over-do it. I can get my OR wheels chrome dipped for like $440 but why should I when I can get the others for $458 shipped to my door?
2006 Nissan Titan XE C/C - Granite, XE Preferred Pkg, Flowmaster SI/DO Muffler, 2* advance, 17" Off-Roads with BFG AT K/O 315/70/17's, AVIC-D3 CD/MP3/NAV/DVD, CST 4" Spindle Lift, 2.5" PRG Spacer, Pro-Comp ES9000 rear shocks, 4" Fabtech block, Fabtech CBDB, chrome door handles, Big Tow Mirrors, Nissan factory hitch, Tekonsha Prodigy Brake Controller, Curt WD hitch
2006 Honda CBR600F4i
- Pearl Blue/Black, Yosh RS-3 Race S/O, Puig Racing Tinted Windscreen, Comp Werkes Fender Eliminator, Gel Grips.
2008 Carson FL162 Fun Runner Toyhauler
PSNissanFleetMgr is offline   Reply With Quote
Old 05-14-2008, 09:20 PM   #2 (permalink)
Yellomantis's Avatar
Re: Ok, so I think I understand backspacing...
With a 4.5" BS the tires will rub BAD! I did that for a while on my mojaves and had to put on my glass fenders to stop the rub.
Not to mention beating the snot out of the pinch weld area!
www.myspace.com/yellomantis
Old 05-14-2008, 09:42 PM   #3 (permalink)
Can anyone else confirm this? I need 5.5" + for backspacing?
Old 05-14-2008, 09:45 PM   #4 (permalink)
REV18K's Avatar
So, does that mean that 04-07, can't fit the 20" stock? What would be the solution.
REV18K is offline   Reply With Quote
Old 05-14-2008, 09:54 PM   #5 (permalink)
Huh? What are you talking about man? What 20's? When did we start talking about 20's?
Old 05-14-2008, 09:56 PM   #6 (permalink)
Nevermind, I just read your mod list in your sig. I thought you only had a leveling kit. My bad!
You should have few, if any, problems getting them to fit.
Old 05-14-2008, 10:13 PM   #7 (permalink)
REV18K's Avatar
the fourm is about backspacing 5.5, so I wonder if the 20" stocks of 08 LE will fit the 04-07. I believe that 20's are 4.5 and was wondering if it was true.
Old 05-14-2008, 10:15 PM   #8 (permalink)
I don't think the backspacing is 4.5 on the newer 20" OEM wheels. The overall suspension design is the same throughout the years. Only real change has been the brakes, hence the need for the 20's.
Old 05-14-2008, 10:20 PM   #9 (permalink)
REV18K's Avatar
Thanks
Old 05-15-2008, 07:06 AM   #10 (permalink)
OK, so if I buy a set of rims with 4.5" backspacing, does that mean they will stick out farther than the factory ones, since those are 5.5"? I just need to know how this works. The rims I am looking at are 0mm offset and 4.5" BS. Will they work or no?
Old 05-15-2008, 10:37 AM   #11 (permalink)
MFresh's Avatar
The wheels will stick out about an 1" more than stock. A wheel that has 0 offset and 4.5" BS is an 8" wide wheel. The tires you're lookin at 315's is a about 12.4" wide tire.
Normally, the widest tire you can go is about 3 1/2 to 3 3/4 inches more than the wheel width. So, a 12.4" wide tire on an 8" wheel is kinda of pushing it. Even thought I've seen it done before with no problems.
You'd just be hard pressed to find a tire shop who will mount the tires!
And yes the more the wheel sticks out, the closer it gets to the rear inside fender (pinch weld) when you turn.
MFresh is offline   Reply With Quote
Old 05-15-2008, 10:52 AM   #12 (permalink)
hooligan's Avatar
blasphemy! any discount tire, even sears will mount them... hell he works at a nissan dealership so he can have the techs mount them. i had 35" BFG mud-terrains mounted on the OEM XE wheels which are only 7.5" wide.
PRGsite <> PRG/ID prerunner fenders
Old 05-15-2008, 12:39 PM   #13 (permalink)
MFresh's Avatar
Sorry didn't say it hasn't been done before. No need to get angry about it.
Old 05-15-2008, 04:29 PM   #14 (permalink)
He's not getting angry, just making up for the K-Mans absence.
I believe I understand... 54warrior Off-Topic Discussion 42 04-10-2008 02:17 PM
I don't understand !! ProjectTitan007 Titan General Discussion 12 06-28-2007 06:38 PM
please help me understand chris boblitz Titan Wheels, Tires & Brakes 10 11-27-2006 02:25 PM
Now I understand... Hector313 Titan General Discussion 1 03-31-2004 08:43 AM
