Old 05-17-2008, 03:34 PM   #1 (permalink)
Peytons_Titan08's Avatar
325/65/18 Do Not Fit A Mini Lift W/pics
Went to get them installed today and i couldnt turn more then 10 degrees either direction. Here are some pics of my new setup pre spindle and SAW's. That will be done next saturday. Pics to follow.
removing mud flaps would not have changed anything. still rubbed in the front.
2008 Titan XE KC
Exterior:
DeBadged
6000k HID
FabTech Light bar w/9" Lights
Performance:
K&N CAI
Superchips Cortex
Audio:
Alpine IDA-X001
JL 300/4 Powering - 4 Polk Audio 6.5"
JL 500/1 Powering - 1 JL 10W3v3
Suspension/Wheels:
Total Chaos Upper Control Arms
4" CST Spindle Lift w/4" Rear Block
Sway-A-Way Coilover's (1" preload)
Sway-A-Way 2.25" Rear's
18" Black/Red Ballistic Offroad Jesters wrapped in 325/65 Terra Grapplers.
"LIFE IS GOOD"
Peytons_Titan08 is offline   Reply With Quote
Old 05-17-2008, 05:29 PM   #2 (permalink)
sligsta's Avatar
Re: 325/65/18 Do Not Fit A Mini Lift W/pics
That's a sweet looking set-up. Sucks that you can't run it until you get your lift. I'm so jealous. I can't wait to get my wheels. They say patience is a virtue.
08 SE KC 4X4 SMOKE
sligsta is offline   Reply With Quote
Old 05-17-2008, 05:35 PM   #3 (permalink)
oh well, i tried
2008 Titan XE KC
Exterior:
DeBadged
6000k HID
Performance:
K&N CAI
Superchips Cortex
Audio:
Alpine IDA-X001
Suspension/Wheels:
"LIFE IS GOOD"
Old 05-17-2008, 05:37 PM   #4 (permalink)
Chevy4740's Avatar
Man, I had 325/60/18 with a NCD 2.5 mini lift. I did have to do the pinch weld mod to clear the tires. I almost went with the 325/65/18. The truck will look good with another lift.
[IMG][/IMG]
My old Ride. My new ride : Big Red Chevy
Chevy4740 is offline   Reply With Quote
Old 05-17-2008, 05:41 PM   #5 (permalink)
wanted a 35"
2008 Titan XE KC
Exterior:
DeBadged
6000k HID
Performance:
K&N CAI
Superchips Cortex
Audio:
Alpine IDA-X001
Suspension/Wheels:
"LIFE IS GOOD"
Old 05-17-2008, 09:09 PM   #6 (permalink)
husker1206's Avatar
35's fit just fine with a leveling kit
2005 CC LE 4x4: 2" leveling kit
35-12.50-18, Nitto Mud Grapplers
Volant CAI, Helix TBS, 2* Advance
Borla Dual Exhaust
husker1206 is offline   Reply With Quote
Old 05-17-2008, 09:52 PM   #7 (permalink)
sligsta's Avatar
Maybe on stock wheels but with wider wheels and less offset they won't. I asked PRG about fitting 35's on a 9" wheel with 5" of BS and he said they would rub badly even with a 1.3" leveling kit(wich raises the 08's 1.5" because the 2" will cause the UCA's to hit the coil bucket).
08 SE KC 4X4 SMOKE
Old 05-17-2008, 10:49 PM   #8 (permalink)
MoValleyTitan's Avatar
I installed 325/60/18 on Helos Maxx6 (18x9, +18 offset) with just a leveling kit and I did't have any issues, didn't even have to do a pinch weld mod.
MoValleyTitan is offline   Reply With Quote
Old 05-18-2008, 12:08 AM   #9 (permalink)
NorCal 4x4's Avatar
The backspacing on a 9" rim with +18mm of offset is about 5.79". Stock 18s have 5.5" b.s., which explains your success. That and the fact your tires are the shorter 33s ... not 35s. But you if you wanted to, with that b.s., you probably could easily run 35s with the pwm.
Old 05-18-2008, 05:46 AM   #10 (permalink)
Does the Xe have different clearance then the PRO-4x?
In this link Just finished the lift kit...325/65/18 35" inch tires on stock wheels 325/65/18 fit, awesomely, its on i think a 2004 titan, 2"front leveling, 2"rear block..and those 35"tires fit no prob... just sorta weird how your 08 Xe wont clear those at all...
I'm just waiting to order new tires for my pro-4x, and was wondering the largest Nitto terra grapplers that would fit with a 2.5"front leveling, and 1.5"rear block, PRG mini lift..stock wheels, 18x8... just looking for some opinions and or users like you that tried this and it wont fit, then guys that are running them and love it.. I have a thread started just yesterday about this..
thanks anyways, nice wheels !!
cfh004 is offline   Reply With Quote
Old 05-18-2008, 08:04 AM   #11 (permalink)
No, if you use STOCK WHEELS as that guy did in your link, they will fit with just a leveling kit. If you go aftermarket like Peyton did, they will not fit.
2006 Nissan Titan XE C/C - Granite, XE Preferred Pkg, Flowmaster SI/DO Muffler, 2* advance, 17" Off-Roads with BFG AT K/O 315/70/17's, AVIC-D3 CD/MP3/NAV/DVD, CST 4" Spindle Lift, 2.5" PRG Spacer, Pro-Comp ES9000 rear shocks, 4" Fabtech block, Fabtech CBDB, chrome door handles, Big Tow Mirrors, Nissan factory hitch, Tekonsha Prodigy Brake Controller, Curt WD hitch
2008 Carson FL162 Fun Runner Toyhauler
2008 Kawasaki Teryx 750 4x4 - billet exhaust tip, 4 seat cage by JG Fab, 6" KC Daylighter HID's, Race-Trim 42" Bench, 4-point Crows, Custom Red Canvas Top, Billet Green Sticker Plate, much more to come (as funds allow).
PSNissanFleetMgr is offline   Reply With Quote
Old 05-19-2008, 12:16 AM   #12 (permalink)
Hawaiianbasshead's Avatar
gonna try my 20x9" +18mm this week with 35"s, but I have a 2.5" leveling kit 05 XE 4x4 w/OR and I have a 3" body lift, so I imagine they'll clear. I'll be posting plenty of pix when I get-er done whether they clear or not
Old 05-20-2008, 05:41 PM   #13 (permalink)
for some reason im stressing these will rub on the spindle or god forbid not even fit. im losing my mind to be honest.
2008 Titan XE KC
Exterior:
DeBadged
6000k HID
Performance:
K&N CAI
Superchips Cortex
Audio:
Alpine IDA-X001
Suspension/Wheels:
"LIFE IS GOOD"
Old 05-20-2008, 06:18 PM   #14 (permalink)
I'm feeling you man. I was VERY close to getting some mud grapplers mounted on my 20"s today but I'm getting spacers 1st just in case.. I'm gonna be really bummed if I get some tires mounted and I can't fit them I don't have nor am I planning on getting a real lift so I can't have it not fit really
Old 05-21-2008, 09:47 AM   #15 (permalink)
sligsta's Avatar
Dude don't sweat it. You should be good with them fitting with your lift. I've read some tires will rub on the spindle but if that happens you should be OK with a thin spacer, probably like a 1/4 inch.
08 SE KC 4X4 SMOKE
Looking for 2in front 1in back Mini Lift Pics BLOWBYU Titan Suspension 0 06-25-2007 02:29 PM
Mini Lift = Big Results *Pics TexTheTitan Titan Suspension 21 06-24-2007 08:37 PM
2.5" PRG Mini Lift Kit Install (Pics) P-Dizzle Titan Parts & Accessories 48 03-22-2007 03:12 PM
PRG mini-lift pics mcq Titan General Discussion 7 06-14-2006 02:11 AM
PRG Mini Lift Pics gixxer0.6g Titan Performance Modifications 11 01-09-2006 10:31 PM
