Old 07-06-2008, 07:31 AM   #1 (permalink)
kpr
wheel stud problem.
need a quick lesson on replacing a broken rear wheel stud. tore everything down,cant see enough clearence to install new stud short of pulling axel out?
2005 titan le.
kpr is offline   Reply With Quote
Old 07-06-2008, 07:38 AM   #2 (permalink)
blavis's Avatar
Send a message via AIM to blavis Send a message via Yahoo to blavis
Re: wheel stud problem.
It might be necessary to chock the front wheels and lift the entire rear of the truck so you can rotate the axle and find a deeper spot on the backing plate. I don't think removing the axle shaft is required for that repair. Good Luck!
iWhore™
AKA BUDWhore™
IRC VK56 Member "Pit Crew Chief"
blavis is offline   Reply With Quote
Old 07-06-2008, 07:44 AM   #3 (permalink)
Quartz's Avatar
Jack up the truck so that both wheels will rotate. Rotate the axles until you find a place where you can fit the stud in. It takes a little doing but I was able to do it to mine. The process taught me a lesson. Don't use the air wrench to tighten lug nuts. I'm back to using the torque wrench.
Old 07-06-2008, 05:33 PM   #4 (permalink)
kpr
thanks.eaiser than i thought.all done and back on the road.
Old 07-22-2008, 09:07 PM   #5 (permalink)
gkings_tx's Avatar
Angry Re: wheel stud problem.
Is there any way I can get some pic I would really appreciate it the stupid people I bought the truck from put the wrong lug nuts on all the tires. I am replacing all the lug studs I am have a problem with the rear wheels. If anyone can help that would be cool.
gkings_tx is offline   Reply With Quote
stearing wheel problem..... SIKTITAN Titan Problems & Dealer Service 0 12-14-2007 09:16 PM
wheel width problem redrocket16 Titan Wheels, Tires & Brakes 1 06-25-2007 01:09 PM
Help broken wheel stud!! Need help A.S.A.P. bigblue06 Titan Wheels, Tires & Brakes 1 06-03-2007 12:42 PM
Broken step bar stud mopar Titan Problems & Dealer Service 2 08-18-2005 07:36 AM
stud monkey racing EPTITAN Off-Topic Discussion 1 08-20-2004 04:49 AM
