The 275/70/18's are only about .5" taller than the 285/70/18 stockers, not 1.5". Unfortunately, from what I've found all of the 275/70/18's on the market are heavy duty tires.
You're running into the same issue I am right now: Finding a proper larger tire for the 18's. The biggest issue you run into is that the HUGE majority of 18" profiles larger than the OEM are heavy-duty/ply tires that weigh a great deal more (like 25%-50% more per tire) which takes a big bite out of fuel economy. It's feels kind of silly putting a 3/4 ton or 1 ton truck tire on the Titan, at least to me.
Personally, I'm just going to bite the bullet, put up with the mileage drop, and slip on the larger tires- in my case the BFG AT's in either 285/65/18 or 303/65/18. I'm guessing my mileage drop will take me from a 13.5 MPG average to a 12 MPG average. Seeing as I'm already getting 3/4 ton gas truck fuel consumption, I might as well have the tires to match.
