Old 12-08-2008, 06:23 AM   #16 (permalink)
loufish's Avatar
Re: Snow/ice traction Nitto Terra Grappler LT
To the OP....Are you running wider wheels then stock?
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 12-09-2008, 01:05 AM   #17 (permalink)
Nope. Stock wheels, stock tire size.
bschram is offline   Reply With Quote
Old 12-13-2008, 07:23 PM   #18 (permalink)
loufish's Avatar
To the OP...
If you're empty in the rear(no real payload) you can run 32-35 psi no problem....Try it and see...
Born 9/2004
2002 Honda XR650R
Old 12-13-2008, 11:54 PM   #19 (permalink)
Pops's Avatar
FWIW, I was looking at my sidewalls today and they say "M+S". I think that means Mud and Snow??
2005 Armada LE 4x4
Superchips Tuned, AirBox Mod, PS2 Game Console, ProComp 6" Lift, Sway-A-Way - Nitto TerraGrappler 325/60-18
____________________________
Old 10-29-2009, 08:09 AM   #20 (permalink)
Ep611's Avatar
I have the Terra Grapplers also, 295/70/17. They are fine on pavement, but last winter I drove in snow and ice (moved from so cal to Idaho) and they packed up with snow very quick. I agree with airing down, but the tread pattern doesn't seem to evacuate very well in snow or mud.
Les Schwab Tire stores up here sell the Mountain Cat ET tires which are drilled for studs. Thinking of going with those this time. Anyone had these yet?
Ep611 is offline   Reply With Quote
Old 10-29-2009, 09:00 AM   #21 (permalink)
DeadRiver's Avatar
Send a message via AIM to DeadRiver
I ended up leaving mine on last winter and share the feeling that they aren't that great in snow and ice.
In fact they weren't that good in sand either..... In wet mud they seem to perform well.
Not sure if I'll swap back to stock before the snow flies or not this year...
2004 Sedona Titan LE CC 4wd
Link to DeadRivers' Overhead Racks with Bed Extender MOD Link to DeadRivers Titan Photos
2° | Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | 10" BA Sub in a www.tech12volts.com Enclosure
The Urinator™
DeadRiver is offline   Reply With Quote
Old 10-29-2009, 11:40 AM   #22 (permalink)
Let some air out of them and get two bags of playsand or concrete to throw in the bed. I do this every winter and throw them away in the spring.
bmbroker is offline   Reply With Quote
Old 10-29-2009, 11:56 AM   #23 (permalink)
DeadRiver's Avatar
I run em around 30 if it's deep.
I keep some 6" semisolid concrete blocks in the back for winter traction if the snow equipment isn't loaded.
i just expected more from a terra grappler i suppose... like anything else there's a science.
you have to air them down really low in sand... i've learned that
The Urinator™
Old 11-01-2009, 01:35 PM   #24 (permalink)
I am currently researching tires as I am in need of a set. I was looking at the Nittos but after reading the newest Consumer Reports tests on tires, the Grapplers did not rate very well in any area.
Seems the General Grabber HTS is the highest rated all around tire. It only lists for $105. too!
vtach12 is offline   Reply With Quote
Old 11-01-2009, 03:37 PM   #25 (permalink)
papojengo's Avatar
Originally Posted by bschram View Post
I'd do that except that I'm under the impression that you need to run LT's at 50 psi to be equivalent to P-metrics in load capacity. I'm hearing this from the tire installers as well as from Nitto:
http://www.nittotire.com/assets/safe...t%20Trucks.pdf.
I'm starting to think that the LT's were a mistake, and I should have opted for P-metrics.
well. first off, the only way you would be making a mistake running LT's is if you DONT use your truck for more than a station vehicle. the ply difference is enough reason to want to run a LT. i have run over- and bent decking screws that would more than likely pierce a standard P metric. you have better sidewall construction & protection, and stronger spinal strength due to additional plies. if your just using your titan as a grocery getter or station car... yea, no reason for the LT's.
secondly, i hated the nitto terra grapplers i got about 22k out of them seeing quick wear even with preventative maintenance and i too did not feel impressed with the snow performance. ( im in long island ny had about 6-10" snow fall per storm last year )
on the other hand i also have run toyo mt LT tires and made them last almost 30k hard miles. these handle better in the snow compared to the terra grapplers surprisingly. i run 33x12.5x18 LT tires ( regardless of brand / style) at 40psi around without a load. when towing a load ex: a car, enclosed trailer etc i run 55psi. if your looking for another LT tire, i would recommend Generals AT2, im very happy with them. very comparable design to the BFG AT KOs. only better performance in my opinion and of course much cheaper.
if your looking for a P metric, my father seems to really like the bridgestone dueler REVOs AT tires. he uses them on his nismo frontier year round.
also i keep 4 75lb bags of sand in teh bed when we have snow conditions. this is a tremendous help for rear traction.
'04 4WD SE TITAN - DAILY DRIVER
'05 4WD LE FRONTIER - WIFES WHIP
'70 SS MONTE CARLO - TOY #1
'64 SS CHEVELLE - TOY #2
'92 ALFA ROMEO - WIFES TOY
papojengo is offline   Reply With Quote
Old 11-04-2009, 10:58 AM   #26 (permalink)
Qx_Indulgences's Avatar
I have to disagree about the mud comment. I'm running the Open Country in the 325/60/18 and they have awesome mud performance. I've made it through some soupy stuff with these tires. THey bite well and clear very well too. I've driven these on the dirt, street and put them through their paces. IT is an excellent performing tire. Ask Pops i've but my Qx through its paces. IF i had to buy them again i would in a heart beat. OPEN COUNTRYS ARE AWESOME!
Stock Intake Ram Air Mod, Coolant Bypass & Screen Delete,Spintech Super Pro Street Dumped, K&N Drop in, Gutted Rear Cats, 325/60/18 Toyo Open Country A/T, Black Qx56 Grill , Black BT Mirrors, Tinted Tails
Qx_Indulgences is online now   Reply With Quote
Old 11-04-2009, 11:07 AM   #27 (permalink)
Pops's Avatar
I have to agree that the Grapplers do really well for an A/T tire. Comparing any A/T tire to any M/T just isn't right, that's like comparing A/T against H/T tires, they're an entirely different class. They also did well for me in the little bit of snow and on alot ice in some ice storms we've had, FWIW.
2005 Armada LE 4x4
Old 11-04-2009, 11:17 AM   #28 (permalink)
Hey what Psi are you running these bad boys at?
Old 11-04-2009, 11:25 AM   #29 (permalink)
Pops's Avatar
43-psi. I called Nitto and told them i'm running them on our undersized OEM wheels and they said that shouldn't be any problem if I keep them at 43-psi.
2005 Armada LE 4x4
Old 11-04-2009, 11:27 AM   #30 (permalink)
43 psi it is. THey wont prematurely wear at that PSI?
Nitto Terra Grappler Question cfdeng3 Titan Wheels, Tires & Brakes 12 03-25-2008 11:27 AM
295/70/17 Nitto Terra Grappler A/T Daves_Titan Titan General Discussion 13 04-29-2007 05:07 PM
Nitto terra grappler 325-65-18 wssboard18 Titan Wheels, Tires & Brakes 11 04-20-2007 11:16 AM
Nitto Terra Grappler AT Owners.. BK19702 Titan Wheels, Tires & Brakes 6 04-16-2007 08:18 AM
Anyone Have Nitto Terra Grappler 295/70/17? jpup Titan General Discussion 16 07-05-2005 07:28 AM
