Old 10-21-2009, 12:36 PM   #91 (permalink)
MXtitan24's Avatar
Re: New Nitto Trail Grappler MT!
sweet post some pics
MXtitan24 is offline   Reply With Quote
Old 10-21-2009, 08:12 PM   #92 (permalink)
salstats's Avatar
Talking Re: New Nitto Trail Grappler MT!
gotta wait till tomorrow morning cause it got dark and my phone sux when its dark. but damn i love these tires, sorry Pro Comp tires never looking back at them no more..... but yes guys these tires are so quiet and my truck doesn't shake nor vibrate. i give it 10 out of 10. I will consider buying the same set when these get cooked. now i just gotta see how they handle icy roads when i go to big bear to go snowboard.
2008 SE 2WD:
PRO COMP Kit, PRG UCA, with Radflows 2.5 Externals sitting upfront at 9.5" and rear 3' with MX6 Rear shocks. Nitto Trail Grapplers 35x-12.5-17 Tires. PRO COMP ALLOYS SERIES 6005 rims. Injen CAI,
salstats is offline   Reply With Quote
Old 10-21-2009, 09:08 PM   #93 (permalink)
Nitto friggin rocks!!! I purchased 315/75/R16 (35.0"x12.9") Mud Grappler Xtreme Terrain tires from Discount Tire, these are hands down the best meats I've ever run (had the Toyo MT and BFG MT previously) and they've out performed my friend's Swamper TSL. The Mud Grappler means absolutely incredible trail performance and traction in dirt, mud, and on rocks (decent in snow and on pavement)...so when I wear these out I'll buy the same in a 37". What is so noticably cool is how the sidewall bite into deep ruts, aggressive like no other sidewall on the market. Note, on the pavement Mud Grappler is a smooth riding radial, but loud (which I like).
Here is the 35" Mud Grappler next to my old 33" Toyo MT, note the difference in lug size and spacing between lugs which cleans out well at each revolution; the key to wheeling in mud. On rock they wrap and grip like no other.
LA RANA is offline   Reply With Quote
The Following User Says Thank You to LA RANA For This Useful Post:
HAYNBOI96743 (10-21-2009)
Old 10-21-2009, 09:24 PM   #94 (permalink)
HAYNBOI96743's Avatar
Love them tires man! how is the tread wear? You rotate them often? I'm planning on getting a set I heard they are awesome. Just the noise factor but I love the sound of those tires, lets everyone know you are coming!
HAYNBOI96743 is offline   Reply With Quote
Old 10-21-2009, 10:05 PM   #95 (permalink)
salstats's Avatar
[quote=LA RANA;1895804]Nitto friggin rocks!!! I purchased 315/75/R16 (35.0"x12.9") Mud Grappler Xtreme Terrain tires from Discount Tire, these are hands down the best meats I've ever run (had the Toyo MT and BFG MT previously) and they've out performed my friend's Swamper TSL. The Mud Grappler means absolutely incredible trail performance and traction in dirt, mud, and on rocks (decent in snow and on pavement)...so when I wear these out I'll buy the same in a 37". What is so noticably cool is how the sidewall bite into deep ruts, aggressive like no other sidewall on the market. Note, on the pavement Mud Grappler is a smooth riding radial, but loud (which I like).
hey you know that 315/75/16 arent really true 35x. But rather like 34.5 or so. They are wider then a true 35x but a bit shorter. same with true 35x they are taller but a bit less wider then a 315
2008 SE 2WD:
Old 10-21-2009, 10:34 PM   #96 (permalink)
Hey MX, I have a quick question, do you run the stock lug nuts on your wheels with the spacers? Or do you have the lugs with the little shaft on em?
MrStevie is online now   Reply With Quote
Old 10-22-2009, 08:25 AM   #97 (permalink)
Pops's Avatar
Stevie, I had to space my wheels out to fit them on (kinda a long story). Anyway, I was suggested to stay away from "Spacers" because they move too much weight to the end of the studs and could possibly break them. It was recommended to go with wheel "Adapters" instead so that's what I did.
The OEM Lugs don't work with them unless they have the same thread pattern (which mine don't). So the place I bought them from included non-capped lugs to bolt the adapter onto the hub then a new set of capped acorn lugs to fit onto the adapters' studs. They also included a set of Gorilla Lug Locks which seem to be pretty nice so far.
Here's what they look like installed:
2005 Armada LE 4x4
Superchips Tuned, AirBox Mod, PS2 Game Console, ProComp 6" Lift, Sway-A-Way - Nitto TerraGrappler 325/60-18
____________________________
Old 10-22-2009, 12:26 PM   #98 (permalink)
MXtitan24's Avatar
I'm running spacers. pops where did you get those adapters i have been looking for a set for a while now
Old 10-22-2009, 01:14 PM   #99 (permalink)
Pops's Avatar
It's a local Mom & Pop shop and they are awesome. They should know what you need if you mention you need the same setup as the Lifted Red Nissan Armada has.
Masseys Accessory Shop Inc
1319 S Robinson Ave
Oklahoma City, OK 73109
405-239-2010
Masseys Accessory Shop Inc, Oklahoma City OK 73109 -- MerchantCircle.com
PM me if they need info to reference the sales order and I'll call them.
2005 Armada LE 4x4
The Following User Says Thank You to Pops For This Useful Post:
MXtitan24 (10-22-2009)
Old 10-22-2009, 06:32 PM   #100 (permalink)
Pops, Greg told me the same thing about the spacers and the studs, but i needed something since the stock wheels won't clear 35's on the spindle. I ended up getting 1/4" spacer and got some lugs that had a little shaft on them and went into the wheel so it would get more lug on the studs, but the lug was too big for the wheel and after awhile they start breaking when I need to rotate my tires.
The adapters look like a great way to go, but I haven't been able to find any that were less than 1", I think a 1/2"-3/4" would be ideal for me. I just bought new rims, but I'm trying to find out the best way to use my stock wheels with 35" terra graps for when i go offroading. I've seen them on ebay for about 100 for 4 of em, how much did they run you? Thanks.
Old 10-28-2009, 03:59 PM   #101 (permalink)
Anyone bought any 305/55-20 Trail Grapplers yet?
OVTitan is offline   Reply With Quote
Old 10-30-2009, 09:15 AM   #102 (permalink)
Pops's Avatar
... The adapters look like a great way to go, but I haven't been able to find any that were less than 1", I think a 1/2"-3/4" would be ideal for me. I just bought new rims, but I'm trying to find out the best way to use my stock wheels with 35" terra graps for when i go offroading. I've seen them on ebay for about 100 for 4 of em, how much did they run you? Thanks.
You're right the catch is that you can't get less than 1". I don't even know if they come that small, the smallest I could get was 1.25". I think it might have something to do with affecting the strength and lug presses in them??
They cost me about $65/ea with all the lug nuts included. There were 2 sets of nuts included, one set to attach the adapter to the hub and another to attach the wheel to the adapter.
2005 Armada LE 4x4
Old 11-01-2009, 12:30 AM   #103 (permalink)
Crappy I-phone photo but here's a one, 35X12.5X17's.
turn_one is offline   Reply With Quote
Old 11-01-2009, 11:08 AM   #104 (permalink)
Lurchdubious's Avatar
Send a message via AIM to Lurchdubious
Looks great!
2004 LE.CC.OR.BT~4x4 (Silver)~6" PC Lift~Deaver C-30+1.5" block~Bilstein 5125's~CST sway bar endlinks~DriveShaft Spacer~ProComp 8128 wheels~35" Nitto Mud Grapplers~PWM~Braided Brake lines~Tech12volt's CDT/Boston/Kenwood Audio~Dynomax "Race Magnum" Bullet Muff~Airbox Mod w/K&N~2+ Timing Advance~Bakflip Tonneau~Titanium pedals/Shifter~Chrome door pillars~20% tint~PRG Offroad Traction Bars
VA Chapter Director
Lurchdubious is offline   Reply With Quote
nitto dura grappler xxjoker19xx Titan Wheels, Tires & Brakes 1 06-09-2009 11:28 PM
Nitto Dura Grappler Review PostRelease Titan Wheels, Tires & Brakes 0 01-20-2009 12:00 PM
Nitto Dura Grappler Review PostRelease Titan Towing & Hauling 0 01-20-2009 12:00 PM
Nitto Dune Grappler Guero Titan Wheels, Tires & Brakes 9 07-03-2008 01:58 PM
295/70/17 Nitto Terra Grappler A/T Daves_Titan Titan General Discussion 13 04-29-2007 05:07 PM
