I was trying to rotate my tires on my 2wd Titan, and after the past few rotations, the front wheels (factory 18's) get harder and harder to remove. I just rolled over 100,000 miles. It seems like the wheels and the mounting face on the rotors are getting joined together (from heat?). Has anybody else run into this? If so, do you have a fix for preventing it?
overview
08 KC XE Galaxy Black, Color matched front and rear bumpers, De-Badged, Charcoal interior, "Carbon fiber" inserts Sound
4 Infinity 6x9's, pioneer head unit, Kenwood 900w amp, Kicker L7 10" sub Performance
K&N w/ airbox mod, Bully Dog GT tuner, flowmaster 50 series Dual 2.25" in single 3" out,2*, PRG 2" leveling kit. Coming soon
UpRev, Nismo headers, JWT cams, IPT trans, Nismo cat back and My tail lights in your face
15.032 @ 92.48MPH
hp295.64 tq330.33
^^^ or a little wheel bearing grease where the wheel contacts the hub/rotor. Just be careful not to get any on the braking surface. A thin film is all you need.
Clean the center hub (the part that goes thru the hole in the wheel) with a stiff wire brush or emery cloth. Check inside of wheel for corrosion, clean in a similar way. Then apply light coat of grease or anti-seize as mentioned.
__________________ - 2004 Galaxy Black KC OR 4x4 -
There's a beautiful view of the end of the world over the bow.
O6 4X2 Granite SE CC FFV, Big Tow & SE Popular Pkg, OEM bed extender and bug deflector, Tekonsha Prodigy, Sylvania Silverstars, Zoomers Canon Exhaust Tip, Armada front spoiler, Parrot CK3100 Bluetooth, NCD 2.5" leveling kit, Go Rhino Dominator II nerf bars, AEM Brute Force, Roadmaster Active Suspension, Bully Dog, Brake Planet drilled and slotted rotors, Wagner Thermo Quiet Ceramic Pads, 08 Shackles.
