Old 09-28-2009, 06:55 PM   #31 (permalink)
silverstar's Avatar
Re: Kumho KL71's on a 3/1" Rough Country Kit..
Since this is the same setup i'm going to go with down to the same tire even I have a couple questions I hope you can help with. How bad did it affect the power of the truck? Did it make a pretty big difference in acceleration or just a little bit. Granted you have the BT gears since you have the pro-4x so your's will be less than mine. Also have you gotten any mpg numbers since the install? How bad did it kill your gas mileage? Thanks for any help.
08 Titan SE 4x4 KC. Magnaflow X-pipe muffler with dual 2.25" tailpipes, Hypertech Max energy. 14.85@91.8 best time(9.49@74 in the 1/8th). 6000k H.I.D. low beams. 302.8rwhp before the hypertech.
silverstar is offline   Reply With Quote
Old 09-29-2009, 09:52 PM   #32 (permalink)
adkl1's Avatar
To tell you the truth they didnt seem to make much of a difference, as far as the mpg i really couldnt tell you i put $20 of fuel in it and it lasts me all week ( 6 miles round trip x 4 days going to work ). i will be going to the mountains next weekend so i will have a better idea about the power loss..
08 Pro-4x moonroof,Tow,DVD,SWB, Airbox mod, 3" RC Kit,35/12.50 Kumho KL71's ..melting in Chandler, Az
Installed 5100 Bilsteins in the rear & waiting for the fronts to come in !!
adkl1 is online now   Reply With Quote
Old 09-29-2009, 10:46 PM   #33 (permalink)
WhiteTitanSe's Avatar
its not a true 3" lift, the spacer is the same exact thickness as a Prg 2.5" spacer and you get no additional lift from the upper control arms, just more clearance.
OP truck looks Great!
04 TiTan Se 4x4
Intake
FlowMasters
2*Timing adv.
9" Pro comp
7" Rear Block + Deavers
20x10 XD RockStars
38x15.50 Kumho Mts
12000k Headlight H.I.D
3500k Fog H.I.D
2 10" Diamond Audio subs with custom box
1200.2 Infinity Amp
Stillen diff cover
OR Skid Plate
Bushwacker Pocket Flares Pain Matched
Matched Handles and rear bumper
NFabWorks Traction Bars
WhiteTitanSe is online now   Reply With Quote
Old 09-29-2009, 11:15 PM   #34 (permalink)
silverstar's Avatar
Thanks and i'll watch for the update after the mountains. Gotta go get some action shots now too! HAHA
Old 09-30-2009, 12:22 AM   #35 (permalink)
Mercenary Marine's Avatar
Your truck looks real good. I have the same kit on my 04, Only mine did not come with tubular upper control arms. You said about camber bolts you bought, did you need them to get it aligned?
Mercenary Marine is offline   Reply With Quote
Old 09-30-2009, 01:47 PM   #36 (permalink)
adkl1's Avatar
Yeah I had to put the camber bolts in because of the lift. Nissan just puts in regular bolts in from the factory..
Old 10-06-2009, 12:01 AM   #37 (permalink)
Hey OP...
Your set up looks good. Definatly will have to look into this kit. thanks for the write up. what did you use to grind down the coil bucket?
2009 White CC 4x2
S&B intake, 22" Magnaflow swap, 28% Tint on front windows and sun strip, DDM 6000k HID
619-TITAN is offline   Reply With Quote
Old 10-06-2009, 12:58 AM   #38 (permalink)
adkl1- that looks sweet! Really like it looks real tough! Love the Pro-4x!
2008 Titan Pro-4x CC LWB Big Tow
Mods:
AEM Brute Force CAI
Flowmaster 50 series
Nitto Terra Grappler 275/70 18
Other toys:
2007 Honda Foreman 500 ES 4x4
2007 Honda Rancher 420 ES 4x2
1997 Nissan Hardbody 4x2 with 250,000 miles!
1997 Nissan Sentra 185,000 miles!
08PRO4X is offline   Reply With Quote
The Following User Says Thank You to 08PRO4X For This Useful Post:
adkl1 (10-06-2009)
Old 10-06-2009, 04:05 PM   #39 (permalink)
adkl1's Avatar
I have a harbor freight handheld grinder and just a 4" metal grinding wheel/disc from the Home depot or any hardware store.
Old 10-06-2009, 05:59 PM   #40 (permalink)
silverstar's Avatar
Any updates on the mileage?
Old 10-06-2009, 08:10 PM   #41 (permalink)
adkl1's Avatar
I have seem to use about the same amount of gas this week going back and forth to work, i would say its a minimal change. I also got to drive on the Freeway for a few miles doing around 65 and they are pretty quite im impressed !
Old 10-06-2009, 10:25 PM   #42 (permalink)
silverstar's Avatar
Awsome, thank you very much for the feedback. I can't wait to get that lift and those tires on my truck! I HATE these crapyears so bad, especially now that they're bald at 23,000 miles! I've heard nothing but good reviews of the kumhos.
Old 10-06-2009, 11:06 PM   #43 (permalink)
NorCal 4x4's Avatar
'04s came with the cam bolts.
NorCal 4x4 is online now   Reply With Quote
The Following User Says Thank You to NorCal 4x4 For This Useful Post:
Mercenary Marine (10-30-2009)
Old 10-08-2009, 07:37 AM   #44 (permalink)
It is a true 3 inch lift...the key is you turn the strut bucket and that (is like adding a turn to the spring) b/c of the spacer bolt hole locations.....
BigBluepro4 is offline   Reply With Quote
Old 10-08-2009, 08:59 AM   #45 (permalink)
G35Titan's Avatar
I just did the 33x12.50x22 Toyo MT's with the 2.5" leveling kit, and I really like the stance, sits about dead even.
G35Titan is offline   Reply With Quote
Rough country 3" leveling kit Mx851 Titan Suspension 14 08-15-2009 10:28 AM
Rough Country 2" Leveling Kit GaDawg Titan Suspension 3 04-14-2009 04:17 PM
Rough Country Leveling Kit??? dkeenum2 Titan Suspension 2 05-12-2008 04:06 PM
2.5" Rough Country leveling kit. Dubbeditup Buy/Sell 13 03-02-2008 08:37 PM
Old SR-A's and New Kumho MT KL71's sammyv Titan Wheels, Tires & Brakes 1 02-27-2007 03:49 PM
