Go Back   Nissan Titan Forum > Off-Topic Area > War Stories
War Stories This section is for discussion of any races you may have particpated in. If you smoked someone like a pack'o'cools, let us know. Likewise, if you got beat... let us know by what, so we can keep an eye out for it next time.
Old 06-12-2005, 01:07 PM   #16 (permalink)
fdiesel's Avatar
Just Wondering You Guys On The Strip What Tire Pressure Are You Running On Also What Gear D Or 4 I Know Dvc Is Off.i Will Be Going To The Strip Soon With My Buddy And His F-350 Diesel I Want To Run My Best Against Him Need To Know Tire Psi Gear And Burn Out Or Not Anything Helps I Will Be Taking Off My Spare Tire As Well
fdiesel is offline   Reply With Quote
Old 06-12-2005, 08:09 PM   #17 (permalink)
hail108's Avatar
I'm very new to the dragstrip myself but here's what I've been doing:
  • VDC off. I forgot to turn if off once, as expected had a slow launch.
  • Let the tranny shift for you. Seems like part of the advantage of a standard transmission is the ability to feel the clutch, not going to happen with the automatic. (The one thing I miss about my Frontier.)
  • I don't think burning out helps regular street tires, however, I was having trouble avoiding the water last time, so it was better to get it off before staging (yeah that's it). Actually I wasn't burning out, just stomping on it from a dead stop. I'd like to keep from replacing my tranny and tires for a while so I'm leaving the power breaking alone.
  • I did try 91 octane this time, didn't notice a difference, was running slower then last time anyway.
  • Also started with a little over a 1/4 tank. I would have done less but I wanted to get home afterwards.
I've been of the mind set that I want to know what this truck does as it is. So the spare and tailgate have been on and the tire pressures are normal. I'm beginning to feel the bug of shaving tenths of seconds off so I'm sure I'll start tweaking things.
I have found a lot of good help on this subject by searching around here. There are lots of others here with more/better experence than I.
Good luck with the F350, and as it's been said many times, apples and oranges, but it doesn't make it any less fun.
2007 Titan LE, CC, 4X4, Smoke, Stock
2004 Titan SE, KC, BT, POP, DeepWater, Stock (15.418sec 1/4mile) - Traded in for the '07 -
1970 Pontiac Catalina 4dr 6.6L
2005 Honda Accord EX V6 (Yeah, we've raced em, Truck's faster )
hail108 is offline   Reply With Quote
Old 06-12-2005, 09:46 PM   #18 (permalink)
fdiesel's Avatar
thanks hail. i have beat him plenty of time before rolling only off line he take the jump due to he puts on the 4x4 and i stay burnnig tires vdc off with vdc on tire start to burn then engine dies for a second giving him the jump on me.on your 91 octane it take 1 to 2 full tanks for you computer to adjust to the different grade i use 93 all the time i have done the test on 87 and 93 and i defenetly feel the differance.
Old 06-13-2005, 04:55 PM   #19 (permalink)
hail108's Avatar
I'll spend the extra for a couple of tanks and see what happens, thanks.
