War StoriesThis section is for discussion of any races you may have particpated in. If you smoked someone like a pack'o'cools, let us know. Likewise, if you got beat... let us know by what, so we can keep an eye out for it next time.
345hp 6.0L Vortec Max and the 360hp Duramax. Faster than Titan?? - being discussed at Nissan Titan Forums in the War Stories section.
Re: 345hp 6.0L Vortec Max and the 360hp Duramax. Faster than Titan??
Originally Posted by HEMI450HP
Guys...Something you have to remember about the SS is that it is AWD, comes on 20's, and is much heavier than its less expensive ext cab rwd 1500. I have seen SS's run 14.8-15.0 stock, now put that same power into a lighter truck with less drivetrain loss, and you are looking at 14.6-14.7. Now I am new on this site and dont know how fast you guys have the titans running, but that is going to be tough to beat...Tough for the hemi guys as well. I am very jealous of chevy owners because of their wide variety of aftermarket products, but until the same products are available for the Hemi's and Titans, I think we are always going to be second best.
You'r absolutely 100% correct. You're right about the aftermarket, but from the looks of things, the aftermarket is starting to make some serious moves toward hemi performance. When the Titan gets the backing, there is no doubt they will be heavy hitters at the track as well. Us chevy guys are just lucky gm actually did something semi smart and gave us a similar design to the ls1. Otherwise, we would really be in the back of the pack.
They are starting to make progress on the hemi, but most of it is useless until we can get a good tune. We have blower kits available, but they are not running at their peak because of tuning issues. We have a few aggressive cams now as well, but again no tune. I am installing a very mild cam only because it has been proven to work with my superchips tuner. If I had a tune, I would go with an aggressive cam, and a nice set of heads...I guess I will just have to wait....and wait...and wait...this sucks!!
Yeah I'm interested to see what the aftermarket for the Titans will be. I bet they can tune easily. I'm just waiten to see a turbo titan . Hopefully not at the track though..
Originally Posted by glowinstrat
i dis agree. if you guys would push your truck to it max than im sure that i they would be seeing the tails.yes i maybe an a$$hole but if you just push the truck to its max than you would see that we can take it.and are trucks can take a SS.i took one for a ride last night,i walked him up and down the blvd.
please explain "pushing your truck to the max"...
considering you have exhaust and a K&N i would assume you are running very low 15 sec 1/4's..maybe upper 14's in some cold weather..good enough to probably run with the SS...but not good enough to walk one easily..
when i mean to the max i mean.stomp on the gas red line each gear.shift down a gear just to take the lead
Stomping down on the gas, going to redline, and possibly downshifting is called racing. What do you do normally when racing, when you're not going to "the max"? Is there a difference?
How bad did you beat this SS, as far as lenght wise? Did you pull him out of the hole, or play play catchup and pass him? Do you spin at all when racing on the street?
I'm enjoying this!
'04 Armada SE Offroad 4x4
Galaxy Black
K&N Drop In Air Filter w/ airbox mod
Carbotech Bobcat front brake pads at 28K miles (no brake judder, just time to change pads)
Originally Posted by HawaiiTitan
Just to add a few pennies, Motortrend tested the 2005 Silverado SS (RWD) 0-60 in 6.7 seconds and 1/4 mile in 15.1 seconds http://www.motortrend.com/roadtests/..._ss_silverado/ Pretty close to a Titan if you ask me....
That sounds about right to me. I honestly can't believe most are giving them the benefit of the doubt on those mid 14 claims. I've seen some SLOW stock SS trucks at the track, but hey, I've never owned one. I do know the VHO and Vortec Max trucks are putting down some good numbers stock. The ss is just too damn heavy to be fast "stock". AWD is good for one thing....and its not the big end of the track.
if were going to talk stock power and speed then i will say i believe the tit an will be faster than a ex cab gm and dodge. that is saying the gm has a 5.3l and the dodge has a 5.7l.
now compare a 6.0l gm with a tit an and dodge than i know the gm will win. does that make the 5.3 a slow motor. no.......and i'll leave it at that.
until dodge and nissan, and ford (to a degree) along with toyota get the backing gm has in the aftermarket then they will all be left behind once the mods begin.
dodge has tuning issues. great one DC! nissan, well, what does nissan have? exhaust and intakes? what else. same goes for toyota. ford does have some aftermarket value but from what i have seen over the years it's geared towards the L.
i am not here to flame anyones brands. you have your truck and i have mine. mine isn't better than yours, but yours sure as hell aint better than mine.
Mine is faster than yours. I have vid to prove it!!!!
