Go Back   Nissan Titan Forum > Off-Topic Area > War Stories
War Stories This section is for discussion of any races you may have particpated in. If you smoked someone like a pack'o'cools, let us know. Likewise, if you got beat... let us know by what, so we can keep an eye out for it next time.
Old 01-01-2006, 02:10 AM   #1 (permalink)
345hp 6.0L Vortec Max and the 360hp Duramax. Faster than Titan??
It looks like Chevy is playing the hp game by introducing the 345hp 6.0L (SS motor) on regular Silverado 1/2 ton extended cabs with the "LT" package. Also, they've upgraded the Duramax diesel to 360hp/650tq.
Has anyone had a chance to run against either one of these yet in their Titan?
The 345hp/380tq Vortec "Max" 6.0L, now available for Silverado "LT" extended cabs, should be about equal in performance to the Titan. I'm assuming this because the 2wd Silverado SS is usually a few tenths faster in the 1/4 mile. However, I think the SS comes with a 3.5" tuned exhaust system which helps it a little.
As for diesel power, the upgraded Duramax sounds pretty stout at least on paper. I think the old 310hp/605tq Duramax diesel's ran low 16's at best bone stock depending on model. However, the '06's with 50 more hp/tq should now be in the high 15's which is approaching Titan performance numbers. Any comments?
'05 Titan XE
K11 Smoke
18" LE wheels-Leer 700 tonneau cover-Ram air hood scoop-SRT-10 rear spoiler-PRG leveling kit-OEM bodyside moldings-OEM foglights-Dunder upper/lower grill-Painted brake calipers-Stainless exhaust tip-Hellwig rear swaybar-Armada front airdam-Rear storage bin-All weather mats-Microfilters-Alarm with power door locks-Hood decals-Fram airhog-Tint.
Coming soon: Painted rear bumper-Bullydog-OEM bed extender....
miketan is offline   Reply With Quote
Old 01-01-2006, 08:08 AM   #2 (permalink)
Deepwater's Avatar
Re: 345hp 6.0L Vortec Max and the 360hp Duramax. Faster than Titan??
They are going to be even higher in 07!
Check out the thread called Peterson's 4x4 mag for the info.
Deep.
Deepwater is offline   Reply With Quote
Old 01-01-2006, 01:03 PM   #3 (permalink)
Banned
glowinstrat's Avatar
Send a message via AIM to glowinstrat Send a message via MSN to glowinstrat Send a message via Yahoo to glowinstrat
they must be playing some type of game. but think that 360 hp 650 ft.lbs. motor might just spank my titans rear end.
glowinstrat is offline   Reply With Quote
Old 01-01-2006, 01:40 PM   #4 (permalink)
Armada's Avatar
The diesel is in a 3/4 ton truck. About 6500 lbs. It will be quick, but that weight is a killer. He'll not overcome spotting you over a thousand pounds in weight if he is stock.
The 6.0 354 bhp 1500 Silverado will be just about a dead even match for the Titan. It's still mated to a four speed auto, and still does not have the low gearing we get from having the equivalent of 4.10 gearing in our lower three gears. Those are two strikes against the high output engine. He'll probably be wearing 20 inch rims too, which will hurt him some.
I've run Denalis and Escalades with that 6.0 engine. My Armada runs pretty consistent 14.8's to 15.1's depending on temperature and humidity. No mods of any kind except the "airbox mod" and a K&N drop-in and synthetic fluids in the engine and both diffs.
Against the 3 or 4 6.0 GM SUV's I've run, here is what I see: Our gearing helps a great deal off the line. I pull away coming off the line. In the midrange, the GM tries to close the gap some and then I pull away on the top end.
Typically by 90-95 mph I am holding a 2-3 length lead. That's about 2 tenths of a second difference or thereabouts.
I would expect a Titan/6.0 1500 Silverado to be similar.
'04 Armada SE Offroad 4x4
Galaxy Black
K&N Drop In Air Filter w/ airbox mod
Carbotech Bobcat front brake pads at 28K miles (no brake judder, just time to change pads)
Armada is offline   Reply With Quote
Old 01-01-2006, 02:03 PM   #5 (permalink)
Banned
wow them things weigh a lot more then i thought i thought they only weight about 5000.
Old 01-19-2006, 09:21 PM   #6 (permalink)
I wouldn't worry about the DuraMaxs: I would take an import over a Silverado weather it had gas or diesel in it. Without trying to sound sexist.. I have to agree with one of my customers; GM builds the thier trucks to cater to soccer moms; and not to a truck market.
Americans tend to want to ask things of our trucks the engineers could never have imagined. I doubt any engineer at Chrysler ever really considered what would happen if a Dakota was asked to carry over 3000# in the bed; or tow 8000-9000# with a 2.5L.
SRTdealer is offline   Reply With Quote
Old 01-20-2006, 06:29 AM   #7 (permalink)
The 6.0L in the ext. cab. should post a low 15 - upper 14 sec 1/4. Many GM owners were doing 6.0L swaps and getting these numbers...
I also here the 6.0L will be available in the reg cabs also...
With the huge aftermarket these trucks have, they will be a force to be reckoned with..
Heavysled is offline   Reply With Quote
Old 01-20-2006, 07:11 AM   #8 (permalink)
PTitan's Avatar
It's nice to have all that power, but at a cost.....gas. When you step on it, the gas gage will move as fast as the speedo....LOL.
PTitan is offline   Reply With Quote
Old 01-20-2006, 07:24 AM   #9 (permalink)
The 6.0L SS is a pretty fast ride. I have heard of
magazine reviews that rate it at 14.9 seconds.
They are quite a bit lighter than the SUV models
with the same engine. The new 06 SS is weight
rated somewhere around 4660lbs. For being a
4 dr. vehicle that is light! Couple that with AWD and you are
talking about some neck snapping hole shots. I
spend at lot of time at silveradoss.com and their are
some fast trucks. One of the fastest (2bseen) I
believe on NX he is running in the 11's. And N/A
he is in the 12's. If you look at his list of mods though
you will see why.
TRUCK SOLD. NOW DRIVE A 97 CAMRY
2004 Ram Sport RC/SB
5.7L Hemi
3.92 LS rear end
20" wheels
Mods:
MagnaFlow 6x12X22 baffled muffler
Amsoil Ea drop in air filter (stock air box)
Airaid MIT intake
AIRRAM Jet Stream scoop
Superchips FlashPaq
Amsoil 5W-30
Superchips Data Acquisition
87 octane tuning*Average's*
*0-60 5.90
*1/8 mile 9.35@76
*1/4 mile 14.45@93
*Spare tire and jack removed.
Times revised so as not to upset Gone2
Hemi4Me is offline   Reply With Quote
Old 01-20-2006, 07:24 AM   #10 (permalink)
buzzkillwill's Avatar
Swapping motors is not easy work, and I guess I'm odd in the fact that I can't see doing all that work and spending all that money to make the truck ALMOST fast as a stock Titan or stock HEMI? Why not just buy the Chevy SS, which already has the 345hp motor. Or put on a turbo, or blower, since the aftermarket is there.
I still think once a decent aftermarket for the Titan gets bigger, the balance will shift. The Endurance is just begging to be opened up and let loose. Just imagine a Titan with cams, (notice I said, CAMS-plural) exhaust, CAI, and a decent programmer....WOW or...OR...a turbo, programmer and exhaust!!
SOLD**2004 SE CC Radiant Silver 4X4 w/ Pop. Pkg and DVD
**SOLD
SOLD **2005 Titan XE KC w/ Preferred Package BLACK **SOLD
2004 Chevy RCSB 5.3/3.42gears/Auto/ Intake/Exhaust 15.3 @87MPH
buzzkillwill is offline   Reply With Quote
Old 01-20-2006, 08:22 AM   #11 (permalink)
I agree, not easy work...but numerous people have done it...however, the ones doing it are true truck enthusiasts...and a motor swap is not all that gets done..check out performancetrucks.net...
take a reg cab chevy with a 5.3...good for 15.0 sec 1/4 bone stock...now swap for a 6.0...now good for a 14.5. add CAI, exhaust, custom tune, and a converter (and some good tires) and you have a 13.5 sec truck...
The SS is an idea, but a lot of extra money for all the extra bells and whistles...
Old 01-20-2006, 09:20 AM   #12 (permalink)
How fast is the avalanche with the best motor option? I am not one to race anybody. I've only been in one race with my titan and that was with a newer f150. This guy in an avalanche was tail gating the crap outta me yesterday. I was going to the turning lane and was slowing to about 30 mph. I swear when he floored it past me I heard his wheels squeel a little bit.
jree is offline   Reply With Quote
Old 01-20-2006, 09:29 AM   #13 (permalink)
IF you raced an Avalanche, stock, I dont' think you'd have a problem. The 1500's are powered by the 5.3L, and the HD's are powered by the 6.0L, I believe. Add in their perspective vehicles, aren't that quick.
**SOLD
Old 01-20-2006, 11:11 AM   #14 (permalink)
I wasn't trying to race, gas is too much money. I didn't think they were that fast but this thing sounded like he sqeeled at 30mph
Old 01-20-2006, 11:51 AM   #15 (permalink)
My buddy has a CC Chevy 5.3L with aerochamber exhuast, Volant, and predator tune and it will bark the tires from a 20-30 roll..
Ordered the 3500 Duramax today...titan is on the block. ned946 Titan General Discussion 50 04-25-2008 08:26 AM
A Ram faster than the Titan? Chilicat Titan General Discussion 76 04-09-2007 03:26 AM
Can a Titan spank an Avalanche 2500HD with the 8.1L Vortec? miketan Titan General Discussion 70 12-19-2005 11:56 AM
Titan vs. silverado 2500 Duramax SupraTitan War Stories 20 05-12-2005 10:13 AM
GM Vortec V8 345hp, 380lbft torque QWIKWHIP Titan General Discussion 13 10-14-2004 10:29 AM
