Originally Posted by buzzkillwill
WOW!!
That's hauling arse!!
I know you shared once before, but what size motor and set-up you running in the Camaro?
BTW-I'm sure the Mopar is still your baby, right....
Buzz, when you said "BTW-I'm sure the Mopar is still your baby, right", I wanted to shout like Ali "Whats my name!" LOL.
Right now the Roadrunner is waiting for me to get my hauling arse out there and learn how to do body and paint work to it. The engine is out so I can paint the engine bay also.
The Chevy engine combo is :
454 bored .060 over
TRW pistons 9.5:1 compression with 119 cc heads and .040 gasket, rings are Hastings moly.
Canfield 310cc rectangle port intake runner aluminum heads, 119cc combustion chambers.
Elgin solid lifter cam, .585"/.620" lift intake/exhaust, 258/268 duration @ .050"
lift, 110 lobe separation angle, Installed straight up.
Holley 1050 cfm Dominator carb with adapter flange, Edelbrock Victor 454 oval port intake.
Stock 3/8 rods with arp bolts, stock crank.
2" open headers.
The transmission is a GM powerglide 2 speed with a 3800 stall converter,
the rear-end is a chrysler 8.75" with 4.56 Gears and I'm running Cal-Tracs and the Slicks are Mickey Thompson 29.5 x 12.5 15's.
Hope that helps Buzz.---MMJ
1969 Plymouth Roadrunner street/strip 3700 lbs
New Best 1.60 60', 7.25 660', 11.48 1/4,
best mph117.25 65F/2100ft/ 30% humidity, barometer 29.1 through the mufflers in the desert at Las Vegas all throttle no bottle.
**SOLD**1970 Camaro Bracket Racer 3160lbs
10.78 1/4MPH 124.7
1951 Chevy Truck
10.508@127mph, 1.48 60'
400 smallblock chevy
