Go Back   Nissan Titan Forum > Off-Topic Area > War Stories
War Stories This section is for discussion of any races you may have particpated in. If you smoked someone like a pack'o'cools, let us know. Likewise, if you got beat... let us know by what, so we can keep an eye out for it next time.
Old 11-30-2006, 02:59 PM   #1 (permalink)
BRACEYOSELF777's Avatar
Worked Over A Powerstroke F-250 & Cummins 2500 Ram
First off...these were two entirely different races that took place on different days...but on the same street. But anyways, lets start with the Ford. I was at the red light and I notice a dark alpine green F-250 coming down an emtpy lane to charge the green light probably going about 25-30. Remember...I was at a stand still and the light turns green....I lean fast into WOT to make sure I don't slip. I look to my side....I was half a truck behind then it became even when I hit 50 with the F-250 next to me...noticing that its was a Powerstroke with the long emblem on the side. I started pulling fast after 60 mph and killed it at the next light. It come next to me again...but this time...didn't want to race off the line.
The next day....today....the same strait away...same light....a Cummins 2500 Ram was to my left and to my right...a Suburban. All the trucks...including mine ....where white. Go figure. But the light turns green...and I wasn't expecting a race....I just go like normal to get thru the lower gears to get my cruise speed. Then I noticed the Ram starting to gun it.....and I was like.....not on my watch......I WOT...weird thing is....I stuck neck and neck at around 50 and after 60....I pulled hard on him. The Suburban was somewhere back there but I noticed each time...both the Cummins and the Powerstroke waited when they got speed so they can WOT. Turbo lag maybe? Dunno. I didn't hear the Cummins at the light power braking so I didn't figure he wanted a run. But anyways, those are my two kills that are worth mentioning.
BRACEYOSELF777 is offline   Reply With Quote
Old 11-30-2006, 06:03 PM   #2 (permalink)
QShip's Avatar
Re: Worked Over A Powerstroke F-250 & Cummins 2500 Ram
Sounds like you had fun!
2004 SE KC 4x4 Titan
B & B Exhaust
Volant CAI
Stillen S/C
Stillen Headers
TruTrak
IPT VB
IPT TC
Uprev ECU
QShip is offline   Reply With Quote
Old 11-30-2006, 08:18 PM   #3 (permalink)
Dude, you gotta stop racing diesels and start picking on more Silverado SS's.
'05 Titan XE
K11 Smoke
18" LE wheels-Leer 700 tonneau cover-Ram air hood scoop-SRT-10 rear spoiler-PRG leveling kit-OEM bodyside moldings-OEM foglights-Dunder upper/lower grill-Painted brake calipers-Stainless exhaust tip-Hellwig rear swaybar-Armada front airdam-Rear storage bin-All weather mats-Microfilters-Alarm with power door locks-Hood decals-Fram airhog-Tint.
Coming soon: Painted rear bumper-Bullydog-OEM bed extender....
miketan is offline   Reply With Quote
Old 11-30-2006, 11:21 PM   #4 (permalink)
I've had my share of racing SS...I'm gonna leave them alone unless they pick a fight.
Old 12-01-2006, 01:20 AM   #5 (permalink)
Yahooligan's Avatar
I enjoyed my Cummins Ram, it was fast for being 6500lb. What hurt was having the manual instead of the auto if I wanted to play around. Every time I had to shift I lost boost.
I loved towing with it, though. There was no contest who was the fastest up the hills, I had no problems setting the cruise to 70 and keeping it in 5th gear up any grade towing my Jeep on a 16' flatbed trailer. Trailer? There's no trailer back there...
On land: 2005 Titan SE CC 4x4
On sea: 1984 Scarab 21SS - Marine Power 454, Bravo 1
Yahooligan is offline   Reply With Quote
Old 12-01-2006, 09:51 AM   #6 (permalink)
BRACE, do you think either of the diesels were modded?
2005 Chevy 4x4 Duramax, Predator stacked w/ Edge, Suncoast Stage IV, 4" MBRP exhaust, AFE Stage II CAI, Autometer Boost & Pyro guages.
GMVisitor is offline   Reply With Quote
Old 12-01-2006, 10:07 AM   #7 (permalink)
onehundredk's Avatar
how come i dont get excitment like that..the most ive ever gotten casual driving was with a silverado ss...he smashed the line, and i just casual increased speed...i figured, he can waste his gas. haha
onehundredk is offline   Reply With Quote
Old 12-01-2006, 02:07 PM   #8 (permalink)
Well to be honest...all the Turbo Desiels I've raced ended up the same way. They usually would have the lead and I would end up passing them up at aroun 60. Weird. But the two had to be stock. I've raced a superchiped Duramax and that thing took off at the line while I was trying to find traction...still passed him up.....and that was when I was stock....or maybe he just let up....weird.
Old 12-01-2006, 02:47 PM   #9 (permalink)
Yahooligan's Avatar
Keep in mind diesels have a much lower redline RPM with the same gearing as a gas engine. Running 70mph in my Cummins Ram was about 2200rpm if I remember right, redline was 3000rpm. Before hitting 3000rpm it would slowly cut fuel, so it wasn't like hitting a wall...more like creeping to redline. Newer Cummins Rams have a higher redline, as do the Duramax and PSD.
The diesels weren't meant for top speed, so who knows...maybe they just started to run out of oomph.
Old 12-01-2006, 11:02 PM   #10 (permalink)
Knowing how some guys are out here....my time will come when I will get slaughtered by a modded Desiel.
Old 12-01-2006, 11:15 PM   #11 (permalink)
titan814's Avatar
you can usually tell the moded ones if they have a big nasty 5 inch exhaust poking out the rear. personally i have a hard time getting the diesel guys to run with me.
400hp LS6 CTS-V (the caddy that zigs)
titan814 is offline   Reply With Quote
Old 12-02-2006, 05:57 AM   #12 (permalink)
Thumbs up Re: Worked Over A Powerstroke F-250 & Cummins 2500 Ram
I went with a 4" exhaust after a little research showed not much noticeable difference between that and 5" for EGT reduction , I also went with the MBRP "installer " series which looks just like the original so it's not as obvious that mine is modded. I had to mod my transmission too since it's not recommended to add more then 90-100HP to the original Allison without modding. Yahooligan might be correct about the redline on diesels I just know my truck has a neck-snapping launch then get's a second wind around 50MPH which is probably caused by the Edge defueling between 4th and 5th gear. I don't have anything to compare it too but am very impressed with how fast it will go from 0-90 especially for a 6,700 pound truck.
BRACE those trucks could have very well been modded, the Titan just moves out quick and keeps getting faster
Worked over a Honda Pilot Papa_D War Stories 17 12-05-2006 06:48 PM
Powerstroke primetime Titan General Discussion 2 07-10-2006 08:58 AM
Titan vs Dodge 2500 Cummins Colorado_Titan War Stories 39 04-13-2006 01:26 AM
Does 06' models have all the bugs worked out?? Paulphilly Titan Problems & Dealer Service 5 10-11-2005 10:57 AM
Titan vs Ram 2500 Cummins TD RockyMtnTitan War Stories 50 08-04-2005 06:47 PM
