2017 towing mirrors - Nissan Titan Forum
2016 Titan General Forum General discussion forum for the new 2016 Nissan Titan.
User Tag List
post #1 of 71 (permalink) Old 12-23-2017, 05:50 PM Thread Starter
Quoted: 3 Post(s)
iTrader Score: 0 reviews
2017 towing mirrors
Just purchased a 2017 SL crew cab and I dont like the towing mirrors. Does anyone know if they can be swaped out for the standard mirrors and if they would be just a plug and go?
Thanks
harley2015! is offline
Advertisement
post #2 of 71 (permalink) Old 12-23-2017, 06:19 PM
Quoted: 1 Post(s)
Re: 2017 towing mirrors
Ha, I see I am not the only one. I want the towing package and spray-in bedliner but not those wide mirrors. Makes getting in the garage very challenging. I looked at the trucks with and without mirrors and they look like they have the same trim size. As such, I imagine they should easily swap out. I'd love to hear from someone as well if they can. Perhaps just looking at a parts diagram would give the answer. I checked ebay and they appear to have the same bolt patterns. Also, the towing mirrors are selling for a small fortune. I did see on nissan parts warehouse website that the regular mirror assembly is $185 per mirror and tow mirrors are right under $600. Looks like you could sell the old ones on ebay and recoup the cost. Just have to confirm the pig tails match. Im sure the parts counter or body shop can do that.
lrtexasman is offline
post #3 of 71 (permalink) Old 12-23-2017, 07:37 PM
Quoted: 49 Post(s)
I have to agree with you guys after driving with the towing mirrors for a bit. I wanted the utility package to get the utility track rails and spray in liner. But, there was no way I could have avoided the towing package then.
I have a half an inch to an inch on either side of my tow mirrors to my garage doorway. When I bought the truck, I measured the difference between the tow and the normal mirrors. Wish I remembered what it was. 2 or 3 inch wider on each side. That would make my garage a lot easier. I also go down a lot of very narrow roads with trees right on the edge and passing cars. Gets a little hairy sometimes.
Curious to see what you guys figure out. I wouldn't mind getting the standard mirrors either.
adamjt is offline
post #4 of 71 (permalink) Old 12-23-2017, 07:55 PM
terry32506's Avatar
Quoted: 61 Post(s)
Thanks
I have the same Truck and I love my tow mirrors. Why don't you like yours?
terry32506 is offline
post #5 of 71 (permalink) Old 12-23-2017, 08:12 PM
Quoted: 32 Post(s)
The 1st generation mirrors could be easily swapped between towing and regular mirrors, so I don't see why the 2nd generations would be any different. As far as I remember, it's a simple plug-n-play project that just required removing 3 or 4 bolts and reconnecting the wiring harness. In fact, I think there's writeup here somewhere with details on how to do the swap.
This might be helpful (although I'm sure you might be able to find better diagrams somewhere else):
https://www.courtesyparts.com/auto-p...e-mirrors-scat
ncbartschi is offline
post #6 of 71 (permalink) Old 12-24-2017, 06:56 AM
drpeeb's Avatar
Quoted: 217 Post(s)
If you haven't already, before doing anything you should probably measure how far out the non-tow mirrors are from your truck first, and compare that to your tow mirrors. I'm not sure the non-tows are that much narrower. The tows give you added height, the separate convex mirror, and the ability to extend the whole mirror outward; just not sure they're actually wider when retracted. Maybe an inch or two? If so, maybe that's enough for what you need.
drpeeb is offline
post #7 of 71 (permalink) Old 12-24-2017, 01:11 PM
Quoted: 10 Post(s)
I'm curious, but aren't the Tow mirrors manually extendable? Have you checked to make sure they are pushed in all the way?
fsaintl is offline
post #8 of 71 (permalink) Old 12-25-2017, 12:55 PM
terry32506's Avatar
Quoted: 61 Post(s)
Exactly was my thoughts and meant to mention that. I bet those mirrors were already pulled out at time of signing lol
post #9 of 71 (permalink) Old 12-25-2017, 06:22 PM
Quoted: 49 Post(s)
With both tow mirrors fully in the truck width is definitely 4-6 inches wider overall...2-3 inches each for each mirror. I measured when buying for my garage. I just cant remember if it was 2 or 3 inches longer for each tow mirror.
adamjt is offline
The Following User Says Thank You to adamjt For This Useful Post:
Clint (08-20-2018)
post #10 of 71 (permalink) Old 12-26-2017, 08:09 AM
Quoted: 10 Post(s)
I was curious so I checked the specs. Standard mirrors overall width is 93.31 inches. With tow mirrors in all the way it is 98.19, so almost 5 inches wider. Pull the tow mirrors out and now you are at 102.6 inches wide, so just over 9 inches wider. Wow.. that's mailbox banging territory.
fsaintl is offline
The Following User Says Thank You to fsaintl For This Useful Post:
Titan332009 (01-26-2018)
post #11 of 71 (permalink) Old 12-26-2017, 09:11 AM
terry32506's Avatar
Quoted: 61 Post(s)
Call it proper visibility when towing a trailer. Too many people do not have a clue how to set their mirrors when towing. Nissan did a good job designing these tow mirrors. I have had no problem going anywhere with my tow mirrors, car wash booth etc. no problems, why are you guys complaining?. Its actually quite comical to have such a complaint lol
The Following 2 Users Say Thank You to terry32506 For This Useful Post:
mallthus (12-26-2017), RobKar (12-26-2017)
post #12 of 71 (permalink) Old 12-26-2017, 09:37 AM
AZPRO4X's Avatar
Quoted: 31 Post(s)
iTrader Score: 8 reviews
X2 ^^^^
08 Pro-4x moonroof,Tow,DVD,SWB,Banks Monster Exahust, Total Chaos UCA's,Tuff Country 1.5" leveling kit,1" rear blocks, PWM, Radiator ByPass Mod,Bilstein 5100's,Limo Tint,285/65R18 Cooper ATP,Black 18x9 5.71", +18mm, Rims,
2016 XD Pro4X Gasser
AZPRO4X is offline
The Following User Says Thank You to AZPRO4X For This Useful Post:
post #13 of 71 (permalink) Old 12-26-2017, 10:10 AM
4mula1fan's Avatar
Quoted: 1840 Post(s)
Garage
iTrader Score: 3 reviews
This rates up there with the dreaded "moving oil pressure gauge"...
It USED to look like this...
Pow ... ... ... ... ... ... ... ... ... ... ... ... ... .. .. .. . . Ding!
TrainingWheelsWhore™
ChumToeWhore™
08 Pro4X with peeling clear coat. Looks terrible!!
Wife's ride '12 Maxima S Limited Edition
2013 Coachmen Catalina 252RLS Santara Series
Click here for mods
My Pics
So long, Walrus (Wally). Forum legend. Friend.
4mula1fan is offline
post #14 of 71 (permalink) Old 12-26-2017, 10:12 AM
Blackbeauty's Avatar
Quoted: 1098 Post(s)
iTrader Score: 12 reviews
Are you friggin kidding me?
Blackbeauty is offline
post #15 of 71 (permalink) Old 12-26-2017, 10:48 AM
HRTKD's Avatar
Quoted: 1164 Post(s)
Garage
iTrader Score: 2 reviews
If I could figure out a way to retrofit a set of tow mirrors on my Leaf, I would. I thought I've seen everything before, but I stand to correct myself. Complaining about tow mirrors, sheesh. I loved the tow mirrors on my Titan. The visibility they provide is well worth the very small pain of folding them in when going into narrow spaces.
«Granite '07 LE Crew Cab, 4x4, Big Tow, Off-Road» <-- Sold 07/2017
«ClearBra, Leer 100XQ, MM SI9500 Winch, Custom b-pipes, Volant PowerCore, AMSoil bumper to bumper, Uprev tuned, CSF radiator, e-fans, JBA LT headers»
«SAW Coilovers and rear shocks, PRG upper control arms, Hellwig rear sway bar»
2015 Nissan Leaf
2017 Ford F-350 CCLB 6.7L Lariat - The Towing Beast
Jim aka Bionic Whore™, Tutu Whore™
HRTKD is offline
The Following 3 Users Say Thank You to HRTKD For This Useful Post:
RobKar (12-26-2017), terry32506 (12-26-2017), Walrus (12-26-2017)
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Jump to top
Linear Mode Linear Mode
Towing with 2017 Titan RedDirt 2016+ Nissan Titan Reviews 31 09-05-2018 05:15 PM
2017 2nd generation big tow mirrors for 2017 titan 4pro x abrahamseven 2016 Titan General Forum 3 02-07-2018 09:26 AM
2017 towing mirrors harley2015! Titan General Discussion 1 12-23-2017 06:45 PM
2017 SV vibration when towing martyf250 2016 Titan General Forum 5 08-20-2017 06:48 AM
Reaplacing the side mirrors for 2017 SL towing package dburks Titan Parts & Accessories 0 02-20-2017 07:20 PM
You may post new threads
You may post replies
