2017 hvac driver vents 10 degrees warmer than passenger side - Nissan Titan Forum
2016 Titan General Forum General discussion forum for the new 2016 Nissan Titan.
User Tag List
post #1 of 26 (permalink) Old 06-19-2018, 05:24 PM Thread Starter
Quoted: 3 Post(s)
iTrader Score: 0 reviews
I have a 2017 Titan and the two driver vents are always 10 degrees or more hotter in both the summer and the winter. I currently have the drivers set at 62 and the passenger at 70 and the passenger air is still colder. The air output is the same and I have tried all all settings and even manual instead of auto.
Is there a calibration I can do or am I dealing with a bad sensor or head unit? I really don't want them taking my dash apart as I know they will scratch it.
titan78 is offline
Advertisement
post #2 of 26 (permalink) Old 06-20-2018, 04:07 AM
Clint's Avatar
Quoted: 294 Post(s)
Re: 2017 hvac driver vents 10 degrees warmer than passenger side
When I first got my truck three weeks ago, it felt like the inside air from the ducts was warmer than the outside air temp so I turned the temp all the way up and let it get hot then turned it all the way down and now itís been fine since. Could it be the blend door gets caught mid swing? I personally do not like dual temp systems, have had them on a bunch of vehicles and use them as a single temp setting always. Too small of an area to have warm and cold, youíre shoulder is two feet from the person next to you. This is why vehicle prices are insane.
Clint
1991 Mazda Miata Limited Edition
2012 Dodge Challenger SRT8 Yellow Jacket
2014 Nissan Sentra SR
2016 Jeep Wrangler Freedom Edition
2018 Nissan Titan SV Crew Cab 4X4
2018 Nissan Rogue SV AWD
Clint is online now
The Following User Says Thank You to Clint For This Useful Post:
Titan332009 (06-28-2018)
post #3 of 26 (permalink) Old 06-20-2018, 05:47 AM
htoal's Avatar
Quoted: 20 Post(s)
Mine is doing the exact same thing. I called my local dealership and they knew exactly what it was. He said it was some sort of temperature actuator that goes bad. Both sides are set to 60 and the passenger vents are blowing a lot colder than the driver side. Bringing it in on Saturday to get it fixed.
htoal is offline
The Following User Says Thank You to htoal For This Useful Post:
Clint (06-20-2018)
post #4 of 26 (permalink) Old 06-20-2018, 09:18 AM Thread Starter
Quoted: 3 Post(s)
Great and thanks. Do you know if they have to remove the dash?
titan78 is offline
post #5 of 26 (permalink) Old 06-21-2018, 05:29 AM
htoal's Avatar
Quoted: 20 Post(s)
I'll find out on Saturday.... I've been reading about some transmission updates and radio updates for reception so I'm going to get them to do that all at once.... Will keep you ya'll updated.
htoal is offline
post #6 of 26 (permalink) Old 06-22-2018, 01:23 PM
Quoted: 0 Post(s)
Mine is doing the same thing. You don't have to remove the dash to replace the actuator. Although, that part has been on backorder for a while. I was told today (06/22) was the first day they could order them (I'm in Texas). Hopefully comes in tomorrow or next week to replace.
mdb1998 is offline
post #7 of 26 (permalink) Old 06-25-2018, 06:00 AM
htoal's Avatar
Quoted: 20 Post(s)
Dropped my truck off on Saturday morning around 9 and they had it done within an hour..... The service manager said it is a known issue with the actuator on the drivers side. Working like a champ now. I'm also in Texas and it took about a week for the part to come in with the temp in the mid 90's.
htoal is offline
post #8 of 26 (permalink) Old 06-26-2018, 06:46 PM Thread Starter
Quoted: 3 Post(s)
Thanks, you wouldn't have the part number would you.
titan78 is offline
post #9 of 26 (permalink) Old 06-27-2018, 06:18 AM
htoal's Avatar
Quoted: 20 Post(s)
Yeah I can get it this evening when I get home. I thought I left the paper work in my truck but I guess I took it out..... Will let you know.
htoal is offline
post #10 of 26 (permalink) Old 06-27-2018, 07:29 AM Thread Starter
Quoted: 3 Post(s)
Thanks
titan78 is offline
post #11 of 26 (permalink) Old 06-27-2018, 07:36 AM
dbolemiss's Avatar
Quoted: 16 Post(s)
Send a message via Yahoo to dbolemiss
I never compared between the two sides and just keep them set at 60.
I've had the problem where the ac just didn't seem like the compressor was kicking on. I hear the compressor and see the rpm jump when I kick it on. But ever time I bring it in it works fine.
I think this just might be my problem also.
2007 Titan SE - Traded in
2017 Titan Pro4X
dbolemiss is offline
post #12 of 26 (permalink) Old 06-30-2018, 08:08 AM
htoal's Avatar
Quoted: 20 Post(s)
Sorry for the late response. The part they switched out was 27732-3SB0A. it’s known as the actuator Assy-air mix. They also replaced the drivers air mix door motor. Not sure if that’s the same part but it worked!!!! Hope this helps.
htoal is offline
Titan332009 (07-04-2018)
post #13 of 26 (permalink) Old 07-02-2018, 11:29 PM
Quoted: 6 Post(s)
Mine is doing the same thing. The passenger side is definitely cooler, and my wife is annoyed I run the a/c full blast because it's hot as hell out.
2017 Cayenne Red CC 4x4
Go3Team is offline
post #14 of 26 (permalink) Old 07-04-2018, 05:44 PM
Clint's Avatar
Quoted: 294 Post(s)
I put my non contact infrared thermometer in my truck to check and get an accurate temperature from the ducts on both sides. I am getting readings from both sides that are basically even. The issue I have is when itís really hot out the air conditioner seems weak unless itís set to recirculated air, my Frontiers all got really cold very fast. Iíve also noticed with these trucks as soon as you turn the a/c on it goes right to recirculate where all my other nissans didnít or at a minimum stayed where I put it, this one every start up goes back to max a/c. In max the temp goes down to the lower 50ís and when out of the direct sun into mids 40ís or lower. On first start up when really hot it takes a bit until I feel cold air.
Is this how yours functions or am I having a problem that needs looking at?
Clint is online now
post #15 of 26 (permalink) Old 07-04-2018, 11:02 PM
Titan332009's Avatar
Quoted: 68 Post(s)
I would take it in Clint, mine is ice cold! I don't have the split system though. Also the Titan might take longer due to the size over the Fronty. One thing I do is put the windows down to help cool the cab while letting the AC get up to speed
2019 Classic Silver SR5P Toyota 4Runner 4WD
*00 GMC Sierra SLE - 315k totaled 4/2019
*09 Titan KC XE - traded 1/11
*10 Titan KC SE - traded 9/13
*14 Tundra Platinum - traded 2/14
*14 Tacoma PreRunner - traded 3/17
*17 Titan CC S - traded 5/2019 30k trouble free miles
*19 4Runner 4x4 SR5 Premium
Titan332009 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Jump to top
Linear Mode Linear Mode
Driver side AC warmer than passenger side Jesse H Titan General Discussion 3 01-20-2015 07:45 PM
Driver side vent doesn't blow as strong as passenger side Jesse H Titan General Discussion 0 09-11-2013 12:42 PM
Passenger CV Shaft closer to shock than Driver side? rbt Titan General Discussion 19 05-04-2011 12:18 PM
Driver side rubs passenger side don't????? Hueyguy626 Titan Suspension 3 02-01-2011 07:40 AM
Passenger seat warmer on the blink? bvstone Titan Problems & Dealer Service 5 02-18-2009 04:19 AM
You may post new threads
You may post replies
